Go to Post Analyze, adjust, anticipate. Don't panic. - PayneTrain [more]
Unread 18-02-2016, 08:08
nlt5 nlt5 is offline
FRC #5676
nlt5 is an unknown quantity at this point
PWM
We have used all of our PWM slots on the rio and we need one more. Can anyone tell me if we are allowed to use a splitter to run two servos on one PWM port?
Thanks
Unread 18-02-2016, 08:11
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: PWM
Yes that is legal. You cannot split PDP power but you can split PWM signal
Unread 18-02-2016, 08:14
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: PWM
You can also use an MXP extension board to get the extra PWM pins from there.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 18-02-2016, 09:12
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: PWM
If you're running two servos (as opposed to two motor controllers), make sure your 6V and 0V wires are big enough to carry the current to drive both servos; don't use a 26AWG PWM cable.
Unread 18-02-2016, 10:11
FRC #5676
Re: PWM
Great! Thanks for the help and advice.
