Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 18-02-2016, 09:54
lphung lphung is offline
FRC #5994
lphung is an unknown quantity at this point
Issues with battery connectors
Hi all,
We just wanted to share with you some issues that we found with the battery cables in our kit. We found that the end-connectors of some cables from Andymark were not well crimped and some connectors actually failed during our tests of the electrical system. You should check if the end-connectors are solidly attached to the cable (It would suck to have a robot stop during a match because the cable failed)
Unread 18-02-2016, 10:08
skink35620 skink35620 is offline
FRC #0442
skink35620 is an unknown quantity at this point
Re: Issues with battery connectors
We've had issues in the past with AndyMark's crimping. We've found that crimp and torch soldering your own connectors improves reliability.
Unread 18-02-2016, 13:02
FRC #5994
Yes. In our team, one of the mentors had the tools to crimp the broken cables again. We also did this to the remaining cables to ensure that the connectors remained well attached.
Unread 18-02-2016, 13:14
dlsmith dlsmith is offline
FRC #5268
dlsmith is an unknown quantity at this point
In our kit this year the battery cable polarity was actually backwards. They powered up everything and blew a bunch of breakers and damaged some speed controllers. Hopefully nothing else fails later as a result.
Unread 18-02-2016, 14:02
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
lphung, I have a quick question, were these from FIRST Choice, KoP, or purchased directly from AndyMark?
As the Manufacturing Manager here at AndyMark, any time I see a thread like this I am concerned, because I want to make sure that your products are of the highest quality. Our crimping tool here at AndyMark is a 6 ton pneumatic crimp tool. Battery cables provided in FIRST Choice and other places in the KoP are actually provided by other sponsors, not by AndyMark. Our battery cables also have blue AndyMark heat shrink on the ring terminal ends.
We would definitely be interested in seeing pictures of this, and if they were indeed AndyMark battery cables, we would be more than willing to send you replacements, just contact our customer service department at sales [at] andymark.com
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
AndyMark, Inc.
http://www.andymark.com
Unread 18-02-2016, 14:45
Would it be safe to assume that AndyMark makes battery cable assemblies with red SB-50 connectors only?
Unread 18-02-2016, 16:41
n.e.r.d #6
Correct. All AndyMark connectors use the Red SB-50.
AndyMark, Inc.
