Go to Post STEM: Science, Trial, Error, Math. - hrench [more]
  #31   Spotlight this post!
Unread 17-02-2016, 08:51
Re: Are these tanks legal?
James,
I don't recall that rule. There were times when plastic tanks were not allowed, and there were restrictions on how much storage a robot could contain. Heck, I even remember a time when pneumatics were not allowed.
  #32   Spotlight this post!
Unread 18-02-2016, 10:14
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Originally Posted by Daniel_LaFleur View Post
This emphasized statement bothers me ( and this, coming from one whom is distrustful of plastic volumes).
1> Are these items allowed per the rules? Yes.
2> Does a Plastic Volume with threaded ports have an inherent risk? Yes.
3> Should an LRI automatically ban that item? No. (s)he should look at the implementation and decide if enough has been done to mitigate the safety risk and then make a judgment call.
It's the same when you are using sprockets and chain. It is in the design and implementation that makes it safe of not.
First of all, I am not a LRI, just a lowly RI and of course it would be escalated.
Second, there are always tanks available at competitions so replacing a questionable tank is not an undue hardship on the team. A box around the tank is also a safe option.
Third, the blue box on R76 says "Consider pneumatic components sacred". That is stronger language than sprockets and chain. The tank will have a torque specification on the fittings, how does a RI verify that it has never ever been violated?
Last, the push in fitting tanks do have a limited life, but the failure of the fitting results in the tube being expelled in a safe manner.
I personally think the risk of using the tank in question is too high and would not use it even for practice.
  #33   Spotlight this post!
Unread 18-02-2016, 13:30
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by trumpthero786 View Post
Hmm I can't imagine using anything BUT the plastic tanks, but you have far more experience than I do. What sorts of failures have you seen in them?
We always use them. Not the white ones, but we had 5 of the black tanks on our robot last year and that robot that went an entire season, plus two off-season events, and numerous outreach activities without a problem. Just check that your wiring is correct, the compressor shutoff switch is fully functional, and you'll never have a probem. (yeah, there's white ones that are perfectly okay, but if you can't tell the difference between a good white tank and a bad white tank, and you still can't tell after doing some research, you're better off just using something else) We still had one of the bad white tanks for quite a while, and we didn't realize we still had it until someone found it in the bottom of a scrap bin last season. After checking its model number on line and realizing it was one of the failure-prone tanks, we got rid of it immediately.
I was at an event where one of those tanks exploded. Fortunately, I wasn't nearby, but that bang could be heard throughout the entire building. Personally, if I had even the slightest feeling that one of the air tanks might be faulty, I probably wouldn't use it purely out of superstition. However, this doesn't mean those tanks are objectively against the rules, and it also doesn't give an RI the ability to fail you unless the tank is actually not legal. However, with such an ambiguous marking, if those tanks were to be used, it would be wise to figure out what they actually are, and ensure that the documentation legitimizing their use is on-hand.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #34   Spotlight this post!
Unread 18-02-2016, 14:42
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Originally Posted by MrBasse View Post
I worked for Parker Hannifin for several years designing products in their brass fittings division and we utilized a large group of their PTC fitting line in our product. I'd have to dig to find it if I still can, but the rating used to be on the product catalog main page. When you insert the tubing, the proper method is to insert fully and they'll tug to seat the barbs. This deform the barbs a little bit. After being done a few times the barbs no long hold a perfect shape. The metal that makes up the barb itself is only a few thousands thick and won't hold shape for long when being deformed back and forth. I'll see if I can find the spec and get back to you.
The orings just get torn up if your tubing isn't cut properly...
I just got off the phone with a Parker Applications Engineer. Consider my mind officially blown. Parker is completely unwilling to stand behind the reliability of connections made with their PTC fittings. They say the fittings are tested to an ISO spec of FIVE make and break connections and are not willing to publish reliability data beyond that test. I work at NASA Langley Research Center as a contractor, and reliability of pneumatic connections is a BIG deal. I now need to make some calls to our pressure systems safety office. This has the potential to turn into a big hairy deal.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
