Go to Post I remember...my first nationals in 1998, when I was in High School, and thinking "Wow, that's really cool. Engineering looks fun..." - Karthik [more]
Unread 18-02-2016, 14:16
CjDace CjDace is offline
FRC #4284
CjDace is an unknown quantity at this point
Noob Programmer question about coding a PSI Sensor
Hey everybody! Our team is using pneumatics this year and we don't know how to code a pressure sensor (pressure transducer). We thought that asking you guys how to would be better than hours on google. We appreciate any form of help. Thank you in advance!
Unread 18-02-2016, 14:27
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Re: Noob Programmer question about coding a PSI Sensor
Here is a class I wrote for my own team to use this year. You may need to update the calculations base on your own sensor:
import edu.wpi.first.wpilibj.AnalogInput;
 * A class for easily interfacing with the REV-11-1107
 * @author Alex Mechler {amechler1998@gmail.com}
public class PressureSensor {
	 * The analog input that the sensor is on
	private AnalogInput input;
	 * The input voltage provided to the sensor
	private double inputVoltage;
	 * What to use if we are no provided with another input voltage
	private final static double DEFAULT_VOLTS = 5.0;
	 * The slope of the conversion of the return volts to pressure. From documentation.
	private final int SLOPE = 250;
	 * The Y intercept of the conversion of the return volts to pressure. From the docs.
	private final int Y_INTERCEPT = -25;
	 * Creates a new PressureSensor
	 * @param in The port the sensor is on
	 * @param volts The voltage we are providing to the sensor
	public PressureSensor(int in, double volts){
		input = new AnalogInput(in);
		inputVoltage = volts;
	 * Creates a new PressureSensor with an input voltage of DEFAULT_VOLTS
	public PressureSensor(int in){
		this(in, DEFAULT_VOLTS);
	 * @return the analog volts the sensor is returning
	public double getVolts(){
		return input.getVoltage();
	 * Formula comes from the official documentation
	 * @return The pressure in PSI the sensor is reading
	public double getPressure(){
		return  SLOPE * (input.getVoltage()/inputVoltage) + Y_INTERCEPT;
Unread 18-02-2016, 15:23
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
If you use the PCM right, you never have to write any code. There should be a spot for your pressure sensor, and one for your compressor (and a bunch for your solenoids, but you have to get there first ). Once you call Compressor.start() (or your languages local equivalent), the PCM will send power to the compressor until your pressure sensor reads as a full 120psi wherever it is in your pneumatic loop, and then shut off. It will automatically turn on the compressor once it dips below 120 again.
Unread 18-02-2016, 15:40
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
To clarify, if your using an on/off pressure sensor to control the compressor, you need wazateer1's response. If you are going to install an analog sensor for which the voltage varies with pressure and read it through an analog input, you need kmodos is doing. His is in C++, you didn't state what language you are using.
Brian K
Team 1225 Robotics Mentor
Unread 18-02-2016, 16:37
AKA: Alex
FRC #1126 (SparX)
Mine is in Java, not C++.
Unread 19-02-2016, 09:01
VrewDaive VrewDaive is offline
FRC #4284
VrewDaive is an unknown quantity at this point
The question we MEANT to ask, is how would we read the psi of the pressure sensor in the dashboard? we understand that the sensor works automatically Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!
Unread 19-02-2016, 09:22
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The sensor is a digital input. You get on/off, not an analog pressure. You need a separate analog sensor if you want pressure
Unread 19-02-2016, 11:23
AKA: Alex
FRC #1126 (SparX)
If you are looking for a decent sensor, this is the one we are using on our robot and will work with the code I posted above with no modification.
Unread 22-02-2016, 09:37
FRC #4284
Hey! Kmodos, how do you get the information from the sensor, into the driverstation? any idea or is it in the code and were just stupid?
Unread 22-02-2016, 10:36
AKA: Alex
FRC #1126 (SparX)
Somewhere you need to add a Smartdashboard.putString with the getPressure() as the string param
