Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 18-02-2016, 13:57
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
How to wire a flashlight?
Our team wants to wire a normal 5v led flashlight to the robot and be able to turn it on and off. What is the best way to wire it?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 18-02-2016, 14:22
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: How to wire a flashlight?
It would be part of a CUSTOM CIRCUIT and need to be controlled in accordance with R53, and not violate R41, R55, R59, or any other rules I may have missed regulating CUSTOM CIRCUITs.
Unread 18-02-2016, 14:44
ArchdukeTim
mhmm....and what exactly would this custom circuit be?
Unread 18-02-2016, 15:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We put a spotlight on our robot...a cheap $14 unit from Walmart. We only used the LED and reflector from the spotlight. The custom circuit consists of a LM7805 voltage regulator and 3.6 Ohm 5 Watt series resistor, and it also uses a Spike relay. The relay is controlled by a relay output on the roborio.
http://www.simple-electronics.com/20...regulator.html
in case you don't know how to figure the resistance and wire up this type of custom circuit.
Unread 18-02-2016, 15:43
JR0405's Avatar
JR0405 JR0405 is online now
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
You would need to use a relay wired to the Roborio and power the flashlight through the relay from the voltage regulator module
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Also, you could use a resistor sized with 12 volts in mind and avoid the 7805. And like Mr. Forges says, control the 12V with a spike. Depending on how much the led draws, some teams have run them off a port of the pneumatics control module, though personally, I would prefer to use a spike.
Brian K
Team 1225 Robotics Mentor
Unread 18-02-2016, 16:13
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Depending upon the amps, you might be able to power it off the 5v supply of the VRM. You would still have to have that power go through a relay.
Unread 18-02-2016, 16:52
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
I thought that custom circuits powered through a Spike would need to be powered off the 12V PDP output. I guess you could consider the Spike as part of the custom circuit and power it all off the VRM, but I don't know how much the inspectors or Spike will appreciate that.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 18-02-2016, 17:47
There is no requirement that a Custom Circuit be powered off a 12V PDP output. The rules say a Custom Circuit can have up to a 40A breaker. I could not find a rule that says a Custom Circuit cannot be connected to the VRM.
However, looking at the Spike, it needs at least 9.5 volts, so it will not work switching 5 volts.
So, the custom circuit would need its own custom switch.
Unread 18-02-2016, 17:56
ArchdukeTim
Do you know how many volts/amps the PCM supplies?
Unread 18-02-2016, 18:03
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Both when I was a senior in high school and this year (junior in college) we used a spike relay and voltage converter to turn on the flashlight through the PDP.
We used this flashlight. It's a 3V flashlight so we used this voltage converter. The flashlight was cut in half through the body and wires were added to the + terminal and the body (- side). This was connected to the voltage converter which was connected to the spike relay.
ID:	20106  Click image for larger version
461 Westside Boiler Invasion
45 Technokats
Unread 18-02-2016, 19:41
The Pneumatic Control Module User's Guide gives the information you want. The outputs are selectable to be either all 12 volts (battery) or all 24 volts (boosted), and the maximum current delivered to all channels combined is 500 milliamps.
Unread 18-02-2016, 20:42
ArchdukeTim
...Are the voltage converters from the years of the cRIO allowed? We still have ours.
Unread 18-02-2016, 21:01
Yes. You could wire a Spark to the PDP, and the output of the Spark goes to the Voltage Converter. That would allow you to turn on/off the voltage converter.
Unread 18-02-2016, 21:02
ArchdukeTim
So we tried connecting the light straight to a talon and limiting the output to 4.5 volts, but it burned out the light. Will that happen with this?
