Go to Post Scoring ringers is going to be like dating. While a select few will master it with relative ease, the vast majority will need quite a bit of time to refine their skills to an acceptable level. - artdutra04 [more]
Unread 17-02-2016, 21:30
abilash123 abilash123 is offline
FRC #2198
abilash123 is an unknown quantity at this point
Autonomous Time Delay
Ok so im trying to figure out how to get an autonomous for work. I tried to get the robot to drive forward with the code below:
drive.tankDrive(1.0,1.0);
Time.delay(3);
drive.tankDrive(0.0,0.0);
When i run the autonomous the robot just jerks forwards quickly and sometimes it won't even give a response. I tried changing the number in the time delay but it made no difference. Any ideas?
Unread 17-02-2016, 22:42
em202020 em202020 is offline
Driver. Vroom.
FRC #0294
Team Role: Driver
Rookie Year: 2016
em202020 is just really niceem202020 is just really niceem202020 is just really niceem202020 is just really niceem202020 is just really nice
Re: Autonomous Time Delay
What code is in the Time.delay function? Through my quick 10 second look, there is no Time.delay() function is Java...
Could it be doing time in milliseconds?
Unread 17-02-2016, 22:52
It might be due to a motor safety if you are using one and it hasn't been Disabled.
That will shutdown the motors during time delays longer than about .1 seconds.
Unread 17-02-2016, 23:44
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Time.delay(3) should be Timer.delay(3.0)
Unread 18-02-2016, 11:44
Yaseen Yaseen is offline
FRC #0069 (HYPER)
Yaseen is an unknown quantity at this point
I'd recommend using a CommandGroup and using its timeout function.
Let's say you have a command for AutoDriving called AutoDrive that takes parameters for left and right speeds.
In the CommandGroup, you'd write something like this:
PHP Code:
addSequential(new AutoDrive(1.0,1.0), 3.0);
Unread 18-02-2016, 15:52
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
You can also use Wait(). For example, Wait(2.0) to wait 2 seconds. Like Mark said, you need to disable safety, or the motors wont run.
myRobot.SetSafetyEnabled(false);
Brian K
Team 1225 Robotics Mentor
Unread 18-02-2016, 21:47
FRC #2198
Thanks disabling safety fixed it
