Programming issues
can someone take a look at our code to see if they can see anything wrong with it. The only thing it does right now is turn the compressor on. We can drive or do anything else.
https://drive.google.com/file/d/0BzD...ew?usp=sharing |
Re: Programming issues
What is the CAN Bus idea for your pneumatics control module? Also make sure that your not using While Loops in your Telop Code. What would you like your Gate Actuator to do in when you operate it?
Try this code and see if you have manual control of your mechanisms. https://drive.google.com/file/d/0Bww...ew?usp=sharing
You didn't include the Global2.vi file in your project, but I can guess what it contains.
It looks like you have copied an example (Limit Switch?) into your code without understanding what it does. The While loops you have added to Teleop will break the robot program completely. They're going to have to come out. It would probably be best to remove everything having to do with those digital inputs, then see if the robot works otherwise. Tell us what you want the robot to do with those switch inputs. We'll help you learn how to write the program to do it. |
We used a Arduino to send the PWM signal to the motor controllers while they are on the robot and not even 1 out of our 5 Motor controllers worked. Then we took them off to try and switch them and we tested one of the ones that didn't work on the bot but it worked off the bot. We have only tested that one so we don't know if any of the other work. I will test them after school today. I switched the PWM splitter from 1 to 0 in order to test one of the other motor controllers on the other side and nothing happened even though previously we had 1 motor working with the same code. I don't even know what to think anymore can someone please help. |
You didn't mention the switch that I saw in the code. The programming for that switch was definitely going to break the program completely. Take out all of the related code and get the motors running first. You said you're using Victors. Those are notoriously difficult to get the PWM connector properly plugged in. If the LED on the Victor is still blinking when you enable the robot, either it isn't connected right or you have failed to initialize the PWM output it's connect to. |
#7
The motor controllers are wired correctly. The code i have been using to test the motors has no switch code in it it is only programmed for drive motors. |
