Go to Post You can't lose if you submit an animation. Even if you don't win an award, your team wins by just doing it. - David Brinza [more]
Unread 18-02-2016, 16:41
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: PCM Compressor Fault
Originally Posted by DurT1178 View Post
What do you mean by adding connectors? Can you specify, please?
We used these.
http://www.ctr-electronics.com/cabli...le-16-awg.html
Makes a better holding connection in my opinion. I think we got ours from Digikey for a bit cheaper.
461 Westside Boiler Invasion
45 Technokats
Unread 18-02-2016, 16:58
DurT1178 DurT1178 is offline
FRC #1178
DurT1178 is an unknown quantity at this point
We finally figured it out today! Thanks a lot for your help! The problem was that the firmware was up to date, but it was corrupted. So all we had to do was update the firmware and it worked fine. (We also vacuumed off the PCM because the National Instruments Configuration kept saying it was a compressor short). Anyways we will probably take a look at those connectors because they look like they work a lot better than just plugging the wire straight in. Thanks again.
Unread 20-02-2016, 16:22
vanjan14's Avatar
vanjan14 vanjan14 is offline
2977 Alum/171 Mentor
AKA: Jansen
FRC #0171 (Cheese Curd Herd)
vanjan14 is an unknown quantity at this point
We had the same problem here on team 171. Turned out the wireless radio was creating interference on the CAN bus. We had the radio right next to the PCM and the power plug was parallel to the CAN connections.
Moved the radio to a location about 6" away and we are no longer having any problems.
Hope our pain helps some other teams out!
