Here is an stand alone example program I have been using (run as a Java application, not as a Robot program) that connects to our network tables, monitors and then clears the "SmartDashboard" entries.
If you are running your program outside of a robot project, then maybe the way we do our set up would apply to you as well.
package com.techhounds.dashboard;
import edu.wpi.first.wpilibj.networktables.NetworkTable;
import edu.wpi.first.wpilibj.tables.ITable;
import edu.wpi.first.wpilibj.tables.ITableListener;
* A utility to delete (clear) the SmartDashboard keys from the NetworkTable.
* @author pkb
public class ClearDashboard implements ITableListener {
* Entry point into the application.
* @param args You can specify the IP address of the NetworkTable server to connect to on the command line.
* @throws InterruptedException If there is a problem accessing the SmartDashboard table.
public static void main(String args[]) throws InterruptedException {
ClearDashboard cd = new ClearDashboard();
String defaultIp = "10.8.68.2";
//String defaultIp = "127.0.0.1";
String ipAddr = (args.length > 0) ? args[0] : defaultIp;
NetworkTable.setIPAddress(ipAddr);
NetworkTable.setClientMode();
NetworkTable.initialize();
NetworkTable table = NetworkTable.getTable("SmartDashboard");
table.addTableListener(cd);
table.addSubTableListener(cd);
table.putBoolean("Cleared", false);
// Give a bit of time to allow network fetch of keys to show up
Thread.sleep(1000);
deleteTableKeys(table, "", true);
// Give a bit of time for network operations to flush out
Thread.sleep(500);
// Put value back (for testing)
// table.putBoolean("Cleared", true);
* Helper method to recursively delete NetworkTable key/value pairs.
* @param table The NetworkTable to clear key/value pairs from.
* @param indent The leading indent (like: " ") for printing out info.
* @param deleteTable Should we delete the table after clearing its children.
private static void deleteTableKeys(ITable table, String indent, boolean deleteTable) {
System.out.println(indent + table);
indent += " ";
// Delete key/value pairs from table
for (String key : table.getKeys()) {
Object value = table.getValue(key, null);
System.out.println(indent + key + " : " + value);
table.delete(key);
// Process any sub-tables
for (String key : table.getSubTables()) {
ITable subTable = table.getSubTable(key);
System.out.println(indent + key + " {");
// Is it save to delete table entries (and if so should we delete children first?)
deleteTableKeys(subTable, indent, true);
System.out.println(indent + "}");
if (deleteTable) {
table.delete(key);
* Let's us know as values come in.
@Override
public void valueChanged(ITable table, String key, Object value, boolean flag) {
System.out.println("table: " + table + " key:" + key + " value: " + value + " flag: " + flag);
Hope that helps.
