Go to Post No, I'm not a Superhero...I'm a FIRST Mentor. Common Mistake. - Mr. Van [more]
Unread 18-02-2016, 15:09
Team5860-Alex Team5860-Alex is offline
FRC #5860
Team5860-Alex is an unknown quantity at this point
CAN Talon Srx Encoder help needed
We are experiencing issues with labview program and getting our arm to move to a position on button command. Nearly nothing happens once enabled and button is clicked. The motors stutter slighty if touched, but after there is no response. yes we did update firmware, set up individual id's and searched the software reference manual
Here are the begin, teleop, and PID values.
https://www.dropbox.com/s/ecvsyzkcb0...13%29.png?dl=0
https://www.dropbox.com/s/duw2u37fx7...14%29.png?dl=0
https://www.dropbox.com/s/n220tfz4zv...15%29.png?dl=0
Any help appreciated
Unread 18-02-2016, 16:18
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: CAN Talon Srx Encoder help needed
The links aren't working
Head Programmer / Driver
Unread 18-02-2016, 17:06
Matt-T-FRC Matt-T-FRC is offline
Electrical Engineering Student
AKA: Matt Tisovic
FRC #6181 (Northwest State Cryptic Cyborgs)
Matt-T-FRC is an unknown quantity at this point
What PID values are you using?
Unread 18-02-2016, 17:53
The links were active just long enough for me to glance at them and not see anything immediately relevant to the problem.
I did notice that you're doing some very weird things when reading the joystick buttons. You get two copies of the Device Reference, passing each to a separate Joystick Get, and you use two completely different methods of getting the desired button value out of the Buttons array. That won't cause the symptoms you describe, but it is definitely not a clean way to do it. You should just get the Buttons array once, and pull all of the values out of it that you need (using either the array-to-cluster or the Index Array method, but not both).
I didn't have a chance to see whether the PID values looked reasonable, or whether the limit switch settings made sense, or whether the control mode was set appropriately.
