Go to Post The main use of Chiefdelphi is self expression of what FIRST means to you. - Koko Ed [more]
Unread 18-02-2016, 17:22
Maha Kanwal Maha Kanwal is offline
FRC #6070
Maha Kanwal is an unknown quantity at this point
Are detachable bumpers necessary?
Do the bumpers need to be detached (for the inspection process) or can they be fixed? I know about color switching and that's not a huge issue for us, but what's necessary is questioning whether we need to remove the plywood during the inspection process, when they're weighing the robot. Please respond swiftly.
- a rookie team
Unread 18-02-2016, 17:25
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Re: Are detachable bumpers necessary?
They need to be weighed separately, which require the bumper to be removed at least that one time.
Even if they are reversible bumpers
yes the wood is part of the bumper assembly and needs to be removed with it.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Last edited by TikiTech : 18-02-2016 at 17:26. Reason: added answer to wood question
Unread 18-02-2016, 17:28
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Yes, and no.
In theory, if your bumpers are not detachable, there are ways around it (such as measuring the Frame Perimeter). If you have reversible bumpers, then changing your color between matches should not be a problem.
One area that will be a problem is weighing your robot. If your bumpers are not detachable, then they would have a presumed weight of 0 pounds, and your robot WITH bumpers must meet the 120 pound weight limit.
One possible solution:
Go to weigh in with your bumpers off. They will get your weight and frame perimeter at that time. Put your bumpers on for your inspection. I don't think the RI's need to ask you to take your bumpers off for inspection. The inspection checklist does not ask the RI's to verify how fast you can remove/attach bumpers. It does ask that RI's verify that it can display red/blue. If you have reversible bumpers, then that would be an easy question. If you don't, then you will have to demonstrate that you can change colors relatively quickly.
Unread 18-02-2016, 17:35
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Emphasis mine:
Originally Posted by R25
BUMPERS (the entire BUMPER, not just the cover) must be designed for quick and easy installation and removal to facilitate inspection and weighing.
As a guideline, BUMPERS should be able to be installed or removed by two (2) people in fewer than five (5) minutes.
Seems pretty clear.
Unread 18-02-2016, 19:49
EricH EricH is online now
Originally Posted by GeeTwo View Post
Emphasis mine:
Seems pretty clear.
This. If you can't remove your bumpers fairly quickly, you can expect some suggestions from your Robot Inspector on how to make the removal faster.
Unread 18-02-2016, 20:01
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The point of quickly removable bumper is to allow fast turn around between matches. If you can change colors without removing the bumpers then there is flexibility on how fast you can take off your bumpers, but they do need to be readily removable. You will be expected to weigh the robot separately from the bumpers during inspection and possibly during re-inspection.
Unread 18-02-2016, 20:03
Jean Tenca's Avatar
Jean Tenca Jean Tenca is offline
Head Mentor
AKA: "John"
FRC #4488 (Shockwave)
Jean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of lightJean Tenca is a glorious beacon of light
On top of what has already been mentioned, please consider how your robot will fit through doorways with bumpers on. There are multiple events (especially districts) where you will have to fit through a regular door. There may also be post season impacts if you're using your robot for demos. Being able to pull your bumpers off isn't only legally required, you may want to be able to do it quickly and easily for transportation.
Team 4488 Head Mentor
2015: [Carson Division Finalists (World Championship)], [Finalists, Entrepreneurship Award (PNW District Championship)], [Winners, GP Award (CWU District)], [Winners, Engineering Excellence (Oregon City District)]
2014: [Galileo Division Finalists (World Championship)], [Finalists, Quality Award (PNW District Championship)], [Winners, Industrial Design (Wilsonville District)], [Winners, Chairman's (Oregon City District)]
2013: [Rookie All-Star (Curie Division)], [Highest Rookie Seed, Rookie All Star (Autodesk Oregon Regional)]
2006-2012: Mentored various teams in OR and WA
2005: Team 1510 captain, founding member
2002-2004: Team 955 student/captain, founding member
