Go to Post Teams whose goal is to play on Einstein think about strategy differently from teams whose goal is to be selected for an alliance at a district event. - alopex_rex [more]
Unread 18-02-2016, 18:35
Railbots Railbots is offline
FRC #6029
Railbots is an unknown quantity at this point
Autonomous Code Help
We are trying to upload our autonomous code to our roboRIO via tethering and these are the errors we keep getting. How would we fix these?
ID:	20108  Click image for larger version
Unread 18-02-2016, 19:46
Re: Autonomous Code Help
Are you trying to "Run" the Autonomous Independent vi? If so, don't do that.
Instead, run Robot Main (or Build then Run as Startup). When the robot code is running, use the Driver Station to select Autonomous (instead of Teleop) and enable the robot.
