Go to Post Part of the magic of FIRST is the interaction between different teams- and that becomes clear as day as the clock starts ticking. - mhayon [more]
Unread 18-02-2016, 20:41
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Battery Rules
Where are the battery rules in the Game Manual? I looked through the manual to try to find them, but I didn't find anything.
Unread 18-02-2016, 20:42
Re: Battery Rules
R31 has them.
Unread 18-02-2016, 20:47
FRC #5875 (ICE)
Re: Battery Rules
From what I read, there's only one rule for how we mount the battery... Is that correct? Or is there a section or rule other than R33 about the mounting?
Unread 18-02-2016, 20:55
Re: Battery Rules
That is correct.
I'll go a little more in-depth: Orientation (for use) doesn't really matter, though on the side or upright tends to be best. (For charging, upright is important.)
But what you're really after is making sure the battery doesn't move within the robot. Just using velcro might not do the trick; I know for a fact that duct tape is not going to be all that helpful. Many teams will build a battery box into their robot to hold it in one position, and then use velcro or a buckled strap to secure it down.
Unread 18-02-2016, 20:59
FRC #5875 (ICE)
Re: Battery Rules
We have a mounting kit from Andymark that sits on it's side, would we be able to use that in a vertical position?
Unread 18-02-2016, 21:01
FRC #5875 (ICE)
Re: Battery Rules
http://www.andymark.com/product-p/am-2939.htm
Unread 18-02-2016, 21:08
Re: Battery Rules
I don't see why you wouldn't be able to. How you do that, though, is up to you.
FRC #5875 (ICE)
Re: Battery Rules
Thank you
Unread 18-02-2016, 23:53
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: Battery Rules
We are doing exactly that this year - in fact the kit fits nicely in a spare piece of KoP Chassis C-Channel turned face down.
Disclaimer: Rookie Team - Rookie Mentor -- Assume I have no idea what I'm talking about.
Unread 19-02-2016, 01:58
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Battery Rules
That is correct.
Could you elaborate on this? Our current battery charger design has the batteries laying down. What is the downside of doing this? Do we have to completely redesign and rebuild our battery cart?
Unread 19-02-2016, 02:44
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Battery Rules
If the batteries need to vent when charging, they are designed to do so while sitting vertically.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 19-02-2016, 07:05
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Battery Rules
My preference is to charge upright. Truth is it really doesn't matter 99.9% of the time. My UPS has one of its batteries permanently upside down. The battery manufactures generally do not recommend this. Flat is OK. AGM & glass mat batteries have very little free liquid in them. Using a smart charger & charging at recommended charge rates is more important then battery orientation.
Unread 19-02-2016, 07:28
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Battery Rules
We go through so many batteries that we would never think to charge the battery while on the robot. So orientation is not an issue for us.
Regarding the battery mounting rule:
R33 The ROBOT battery must be secured such that it will not dislodge should the ROBOT be turned over or placed in any arbitrary orientation.
"arbitrary orientation" includes turning the robot upside down. Basically, once secured, there is no way to remove the battery. All 6 sides of the battery must be restrained.
Some people use "compression" to hold the battery (squeeze the sides of the battery). I personally don't like it. I would much rather see a strap across the top.
Unread 19-02-2016, 08:20
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Re: Battery Rules
Keep in mind going over the defenses loads the robot is many directions. Having the battery really secure is going to be way more important than in years past.
Unread 19-02-2016, 09:24
philso philso is offline
FRC #2587
Re: Battery Rules
Would a robot that is E-Stopped because it's battery bounced out while crossing one of the DEFENSES be considered a Tortola?
