Go to Post I think there is much to be learned from working in teams, and team projects, but even more when you go out on your own some time for something you are truly passionate about. - paul_v [more]
Unread 18-02-2016, 21:14
Chi Meson's Avatar
Chi Meson Chi Meson is offline
"Strange and Anti-charmed"
AKA: Brian Chidley
FRC #2168 (Aluminum Falcons)
Chi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud of
pic: Jimmy Talon
Unread 18-02-2016, 21:15
swaxman12345's Avatar
swaxman12345 swaxman12345 is offline
Team Member
AKA: Sasha Waxman
FRC #2512 (Daredevils)
Team Role: CAD
Rookie Year: 2015
swaxman12345 is an unknown quantity at this point
Re: pic: Jimmy Talon
my god *inserts dank meme*
Beware the Kraken, Jebediah. - Bill Kerman
Unread 18-02-2016, 22:14
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
You guys took breaking the defenses a bit too literally...
On a more serious note, what was the reason for going with ten wheel as opposed to eight wheel? Or even six wheel?
It isn't shiny enough.
Unread 18-02-2016, 22:39
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
Nice!
Look forward to seeing you at Suffield (and WPI)
Unread 19-02-2016, 14:49
lnex1357's Avatar
lnex1357 lnex1357 is offline
Inspiration through Determination
AKA: Joshua Miller
lnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud of
Send a message via AIM to lnex1357
There are a number of factors that combined toward our decision. The primary goal was to be able to destroy both defenses in at least four categories, risk free. Thus the drive train gained even more value then the already high value we normally place on drive train design. We established a rough chassis perimeter based on the diameter of the ball and the:
-Packaging of our selected shooter through prototyping
-Packaging of our climbing concept
-Packaging our drive train components
Based on the stability and handling performance of 8WD, our original goal was an 8WD. Which left us with two options from our investigating perspective. 6" or 8" wheels. Clearly, an 8" wheel long 8WD with the 120" perimeter rule gives you the optimum defensive terrain crossing ability. However, when designing to go under the low bar safely and maintain our shooter design it was evident every precious inch counted. Through prototyping we determined a 8WD 6" wheel would do the job effectively. As part of prototyping we created a sketch with all the terrain based defenses and our chassis with a spread center 8WD. It was clear that no configuration of wheel spacing with our chassis length would allow us to drive over the moat without high-pointing on our WCD chassis rail. We went back to our prototype and added a 5" free-wheeling wheel in the middle of wheel set. It became evident that this concept would do more hurt than harm and thus we powered it giving us far better results than a standard 8WD, specifically a much smoother transition over the terrain defenses and not requiring us to "dukes-the-hazard" the defenses which we wanted to avoid when we calculated the theoretical loads induced into our shafts and bearings at a average ramming speed of 10 ft/s. We went back to our sketch and incorporated 10 6" wheels and observed that fact that at no point would there be more than a 1.25" gap at the point where the belly pan intersected with our wheels thus eliminating a highpoint from the 1.5" wide mote rails and the uneven terrain. So given our goals and the results of our prototyping, the decision was easy.
Clarkson University 2010 / GENERAL DYNAMICS Engineer / EWCP / FIRST Volunteer
FRC Team 2168 - Aluminum Falcons, [2011-20xx]
FRC Team 229 - Division By Zero, [2004-2010]
"Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek."
Unread 19-02-2016, 15:16
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Nice description of your iterative design process. I've added you to my "teams to watch" to see how the 10 wheels work out. You might become the "North Coast Drive" team.
Any chance for a description how you drive all those wheels? Let me push my luck and ask for a picture too.
Good luck!!
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 19-02-2016, 16:29
lnex1357's Avatar
AKA: Joshua Miller
Good luck!!
See the posted image.
Unread 19-02-2016, 17:23
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Here:
http://www.chiefdelphi.com/media/photos/42803?
http://team2168.org
Unread 19-02-2016, 17:27
edited to add: Thanks James, we cross posted. Thanks for posting the link, that's what I was looking for.
