Go to Post It is not for any other team to say what is beyond a person's or a team's capabilities. That's why they have mentors :-) - preussrobotics [more]
Unread 02-18-2016, 07:44 PM
1572 1572 is offline
FRC #1572
1572 is an unknown quantity at this point
CAN Talon SRX Speed Control
When we set the RPM to 1, the motor spins at 4000 RPM. When we set it to 2, the motor spins at -2000 RPM. When we set it to 3, the motor spins at 250 RPM. When we set it to 4, it goes full speed forward.
How do we fix it?
Unread 02-18-2016, 10:51 PM
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
Re: CAN Talon SRX Speed Control
We have had good success following the CTR Talons SRX Software reference manual.
specifically the 12.4. Velocity Closed-Loop Walkthrough – starting on page 76.
Hope this helps!
2010-2017 Mentor Team 319
2012 - Rockwell Automation Award Winner
2014 - Xerox Creativity in Engineering Winner, Archimedes Division
2015 - Rockwell Automation and Gracious Proffesionalism Winner, Tesla Division
2016 - North Shore and UNH District Event Winner, Carson Division
http://www.frc319.com
Unread 02-18-2016, 11:12 PM
bogally99 bogally99 is offline
FRC #0159
bogally99 is an unknown quantity at this point
How do we fix it?
If you can mount an encoder on the motor you can allow that to regulate the speed control, but otherwise all I can say is guess and test.
Unread 02-19-2016, 12:02 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
That's peculiar enough that I'm going to suggest a thorough type check of all your variables. Are you perhaps sending variables of the wrong types to methods? Floats vs ints vs longs vs doubles can sometimes generate this weird sort of behavior. If you can't find anything, post your code and I'm sure someone will help more specifically.
