Go to Post Don't let what you think you can do get in the way of what you can do. - Daniel_LaFleur [more]
Unread 18-02-2016, 23:33
JABot67 JABot67 is offline
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
PID turning using gyro in LabVIEW
Hi LabVIEW Helpers,
My team is having a problem when trying to tune a PID algorithm for turning the drivebase to a specified relative angle.
The following autonomous code (using only P control) will work as intended, turning the robot approximately 180 degrees and staying there until the robot is disabled:
https://onedrive.live.com/redir?resi...nt=photo%2cPNG
What we find strange is that any non-zero kI will cause the robot to turn toward the setpoint (as expected) and then oscillate vigorously around the setpoint for eternity. This works with kI as low as 1e-12, i.e., nothing.
We would like to use PI control for our autonomous turning VI, but are perplexed by this behavior. As we decrease kI down to zero, we expect that the program's behavior should approach that of pure P control. Perhaps this is a floating point issue?
I remember in high school when programming in LabVIEW we ran into the same problem, but worked around it. Since we only needed to vary the robot's heading by a few degrees in 2010, we opted to set a very high kP and only use P control. This year is different, and we would like to have a turn VI that can reliably turn the robot any amount.
Besides providing us with a solution to this specific problem, what would really help us is some very good example code for turning to a specified relative angle autonomously. Any pointers, advice, or examples are appreciated!
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
Unread 18-02-2016, 23:45
Re: PID turning using gyro in LabVIEW
You actually want kI to be a larger value rather than a smaller value, e.g., try 10 or 100 instead of .1
Think of it as 1/Ti
Unread 18-02-2016, 23:49
Unregistered User
Originally Posted by Mark McLeod View Post
You actually want kI to be a larger value rather than a smaller value.
Is it worth it to start with a non-zero kI and kP of zero, then add kP later? We have not tried that yet. However, the confusion still stands about the fact that there is such a difference between a kI of zero and a kI of 0.000000000001 (1e-12).
Unread 18-02-2016, 23:51
Unregistered User
Ohhh I get it. Ti is proportional to 1/kI.
Edit: Thanks everyone for the quick responses!
Unread 18-02-2016, 23:48
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
In the toolkit the PID is in the Academic Form. So decreasing the Ti constant will increase the Ki gain.
You can verify that if you look at the labels of the three constants you'll see they are Kp, Ti, Td.
You can transform it to the Parallel Form using the PID Structure Conversion VI.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 19-02-2016, 08:58
Here's a slightly off-topic question related to the PNG in the OP.
Is it best to hard-code the control period (0.020 as shown in the PNG) or would it be better to leave that blank and let LabVIEW compute the actual period each iteration (especially with Teleop)? Or doesn't it matter that much in actual practice?
Unread 19-02-2016, 09:37
You only need to specify the control period if you have sub-ms loop times.
Only in rigorous time-controlled loops of course.
The vi itself will compute the actual period using an internal 1 ms clock.
