Go to Post Remember, never underestimate the determination of thousands of FIRST students! - Jay H 237 [more]
Unread 19-02-2016, 12:00
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Bandsaw blade suggestion Metal AND Wood
Our VEX teams have access to a shop that has a little used 14" bandsaw. The owner is willing to install a donated blade on it, but he needs the ability to cut up to 3/4" plywood.
So I'm looking for a compromise blade that will cut the softer steel of VEX metal, aluminum, polycarb plastic AND cut 3/4" plywood. I know that it's not going to be the best in both worlds, but would like to hit the mid-point. Because of the small VEX pieces being able to cut a smaller radius would be a bonus.
I'm looking at carbon steel with a skip tooth pattern to help with clearing the wood chips, but I'm a little out of my depth.
Thanks!
Saw information
Jet JWBS-14DXPRO, 14" Deluxe Pro Bandsaw Kit
Band Saw Size/Wheel Diameter (In.) 14
Cutting Capacity Width (In.) 13-1/2
Cutting Capacity Height (In.) 12
Blade Length (In.) 105
Blade Speed (SFPM) 1500/3000
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 19-02-2016, 12:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bandsaw blade suggestion Metal AND Wood
Use something else to cut steel, and us the finest blade he can get away with for the thicker plywood.
Unread 19-02-2016, 12:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Yep, 1500 sfm is about 8-10x too fast to cut steel, regardless of blade choice.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-02-2016, 13:05
Alrighty then, that was easy! Thanks!
Unread 19-02-2016, 13:48
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We don't run into a lot of scenarios for cutting steel that aren't amenable to the hacksaw or the Dremel. We switched to EZ Lock cutoff wheels on the Dremel and really like them.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 19-02-2016, 14:02
I watched a roboteer use one of them and then drop it. The bounce was pretty amazing. No injuries, but it ended my allowing them to use Dremel tools.
Unread 19-02-2016, 14:54
MrForbes's Avatar
AKA: Jim
I have no use for a Dremel tool on anything I work on. Maybe I have too many 4.5" and 7" and 8" angle grinders!
but at school, we use a hacksaw and vise to cut steel. At home, I use an abrasive chop saw, or a cutting torch, or a 3" air powered cutoff wheel. When we made a steel frame at school, I brought in my chop saw. If I were serious about cutting steel, I'd get a good sized horizontal band saw for cutting stock, and a plasma cutter for cutting sheets. But I'm too cheap.
Unread 19-02-2016, 15:10
We cut VEX metal with a hack saw now, I was just entranced by the ability to get to a bandsaw to cut metal.
Angle grinders fall into the same category of Dremel. Drop them and it spins on the ground. Hard to drop a band saw.
Oh baby, I can just imagine a plasma cutter and the VEX metal plate!!!
Unread 19-02-2016, 15:28
MrForbes's Avatar
AKA: Jim
There are small "convertible" horizontal bandsaws that run at the right speed to cut steel, and can be set in a vertical position.
http://www.harborfreight.com/horizon...saw-93762.html
I have used one years ago, it would probably be OK for light metal like you are planning to use it with, but not so good for heavy stuff I work on at home.
