Go to Post I hate mini-bots. - Gdeaver [more]
Unread 18-02-2016, 20:46
amstrudy amstrudy is offline
AKA: Anja Sheppard
FRC #0900 (Zebracorns)
amstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to beholdamstrudy is a splendid one to behold
Talon SRX not working
So about ten minutes before this problem, the Talon SRX's were doing perfectly fine. Then we took a piece of plastic off of the robot and they stopped working. Now, I try to turn on a motor and the SRX will blink red and amber, with a few spurts of green, like it's trying really hard to turn on. The SRX's use CAN.
Thanks for the help!
EDIT:
We have tried re-imaging the RIO. A Talon SR with PWM also did the same thing. CAN is not the problem, because all of the motors appear in the webdash. I even made another tester program with just one motor and that didn't work either.
Unread 18-02-2016, 23:22
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Re: Talon SRX not working
Can you be a little more specific about what kind of plastic you took off the robot if you think that is the cause of your problems. Is it possible in doing so you bumped the roboRIO and dislodged something inside or something? Or maybe a setting on your laptop changed? Weird that the problem would affect both CAN and PWM if it's not software.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 19-02-2016, 08:12
dlsmith dlsmith is offline
FRC #5268
dlsmith is an unknown quantity at this point
Our team spend 2 hours debugging an SRX problem last night with similar symptoms (our first year with CAN speed controllers...) I would suggest checking the CAN configuration page on the roborio web interface, and make sure that the "soft limits" are NOT enabled. As soon as we unchecked those, voila - it moved again! I don't know exactly how the soft limits work do but the motors didn't move at all; you could see the lights blinking in the pattern as if a limit switch was closed.
Unread 19-02-2016, 12:19
Did you look up the blink codes in the Talon SRX manual?
Alternating red/orange, with the colors swapping sides each blink, means "damaged hardware". I don't think I've ever seen one doing that myself. I'd just replace the Talon (after double-checking the wiring, of course). You should also contact the manufacturer for suggestions.
Unread 19-02-2016, 13:31
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Check your wiring. We've seen similar things happen when connections along the CAN lines are not perfectly secure. I'd suggest these, if you're having trouble keeping secure, consistent connections.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
