Re: Suction cup for grabbing boulder question
Generally in the scheme of FIRST volume vacuums (Like a shop vac, motor driven rotating fan) have been more successful than pressure vacuums (air across venturi or ).
In 2008 as a student on 1741 we used replaced the motor from a conventional vacuum fan housing with a Fischer-Price motor. It generated a vacuum of about 28 inches of water. Obviously a 40" ball makes has a lot more surface area to work with than a 10" ball, but it could still potentially work. A volume vacuum is much more leak tolerant than a pressure vacuum, which is the primary advantage here.
To find components, talk to a local vacuum repair shop. Generally they'll have fan housings with burnt out motors they would be happy to get rid of. It's late in build season, so there isn't a great deal of time to get this implemented, but a 775 motor would probably do a great job in the application.
If you have any questions, let me know. I'd be happy to help.
Good Luck.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
2015-Present Ri3D Team Indiana - Mechanical and Fabrication
