Go to Post Woody says that gracious professionalism is "acting how you would if you grandmother was watching you"... some people must have some really crazy grandmothers. (: - Cappeh [more]
Unread 19-02-2016, 14:38
gofmannir gofmannir is offline
AKA: Nir Gofman
FRC #2096 (RoboActive)
Rookie Year: 2015
gofmannir is an unknown quantity at this point
How to do two actions on the same time?
Hello
How I can program that two motors (for example) move at the same time...
In the autonomous I'm using the set() method and after that the delay() and that again set() to stop the motor..
How can I move two motors on the same time?
Unread 19-02-2016, 16:54
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: How to do two actions on the same time?
If I understand you correctly, you have something like:
motor1.set(1.0);
wait(3.0);
motor1.set(0.0);
To control two motors at the same time, you can just do:
motor1.set(1.0);
motor2.set(1.0);
wait(3.0);
motor1.set(0.0);
motor2.set(0.0);
