Go to Post Chances are it's an electrical or mechanical problem... - mechanicalbrain [more]
Unread 14-02-2016, 17:27
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Dual encoders
My team is running a tank drive setup this year, and have added an encoder onto each side. We are also using the NavX for angle measurements. We will have a variety of methods that rely on angle measurements from the NavX and distance measurements using one or both encoders.
However, I am wondering if there is really any benefit to having both encoders. If for distance we just take a raw average of both measurements, we are basically getting slightly more precision in exchange for a doubled failure rate. It seems to me that unless you are using two encoders to sense angles in place of a gyro (or some sort of fusion) there is almost no benefit to having dual encoders.
How does your team integrate dual encoders into the code? Does anyone just mount/use a single encoder?
Unread 14-02-2016, 17:39
Re: Dual encoders
If you play your cards right, you can use the redundancy to reduce the effect of an encoder failure.
Unread 14-02-2016, 17:47
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Dual encoders
In industry, we would actually use 3 encoders and then always select the midvalue one.
Just as we say:
- With 1 sensor, you don't know that you're wrong.
- With 2 sensors, you know you're wrong but aren't sure which is correct.
- With 3 sensors, you always know which one is wrong and which is right
(From a single-fault-tolerance perspective)
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 14-02-2016, 17:48
Re: Dual encoders
Does anyone actually do this in FRC? I had played around with the idea of constantly checking both encoders, and if one is consistently outputting zero (possibly indicative of faulty wiring), switch to the other one. Are there any other common failure modes that we could look for?
Unread 18-02-2016, 13:51
Re: Dual encoders
I'm still hoping for answers. If I don't get any responses, I will assume that everyone just averages the two values.
Unread 18-02-2016, 14:03
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Dual encoders
Two encoder are essential for drive straight using encoders. If one gets ahead of the other, you can adjust the direction. It all goes out the window when crossing defenses though.
Former Mentor Team 1771
Former mentor Team 4509
Unread 18-02-2016, 14:41
Hjelstrom's Avatar
Hjelstrom Hjelstrom is offline
FRC #0987 (High Rollers)
Hjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond reputeHjelstrom has a reputation beyond repute
Thumbs up Re: Dual encoders
Ok I'll chime in, we typically end up using just one encoder and the gyro even though we have two encoders.
Some years, we have implemented some code which has some logic like the following "psuedo-code":
if ((encoder count isn't changing) && (trying to drive))
encoder_is_broken_counter++;
else
encoder_is_broken_counter = 0;
const int ENCODER_MUST_BE_BROKEN_COUNT = 100;
if (encoder_broken_counter > ENCODER_MUST_BE_BROKEN_COUNT)
ABORT_AUTONOMOUS_MODE!
Maybe one could improve on this logic to switch which encoder you are using, switch from averaging the encoders to ignoring the one that isn't working?
Typically we run out of time to do all of the fancy stuff we would like to do in autonomous.
Unread 18-02-2016, 15:13
We use 2 encoders and check if one or the other is where we want, that way we can handle a single encoder failure.
Unread 18-02-2016, 15:20
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Dual encoders
^ Same, we typically just check if either is greater than target, and call it good. Close enough for FRC... We use $60 encoders, not wanting to buy another, to know which is broke, as I am broke. . .
The sooner we get behind schedule, the more time we have to catch up.
Unread 19-02-2016, 01:20
mehnadnerd mehnadnerd is offline
AKA: Brendan
FRC #1458 (Red Tie Robotics)
mehnadnerd is an unknown quantity at this point
Re: Dual encoders
Having two encoders also helps to ensure driving straight. The way we implement it can be found at https://github.com/FRC1458/turtleshe...tDrivePID.java, we combine the gyro data and the difference (left - right) to figure out how much the motors need to drive differently.
Unread 19-02-2016, 14:11
Re: Dual encoders
Can you tell which one is behaving correctly and which one is failing? Or do you just abort if they are different enough?
Unread 19-02-2016, 15:07
Re: Dual encoders
His description suggests that it accounts only for an encoder reporting too few counts. If either of the two reaches the target, the code considers the travel distance satisfied and continues to the next step. Since the typical encoder failure results in it not counting at all, this is highly likely to have the desired result.
Unread 19-02-2016, 15:25
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: Dual encoders
We have encoders and potentiometers on all of our joints, both for zeroing and fault detection. Last year we correctly e-stopped our elevators when one of the encoders got unplugged. Not the drivetrain, but still a use of redundancy.
