Go to Post You can never be done too early for more testing and practice! - Donut [more]
Unread 18-02-2016, 09:19
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Robot project doesn't load on new laptop
I have copied the robot project to a usb flash drive but the project doesnt open on my new laptop.
I double click the project and it just opens LabVIEW but not the project,
I have also tried to use File>Open but it didn't work either.
How can I fix this?
Thanks.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 18-02-2016, 10:00
aeastet aeastet is online now
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
aeastet is an unknown quantity at this point
Re: Robot project doesn't load on new laptop
Did you only copy the .lvproj file? If so that is not everything you need. If not could you show a screen shot of what you did copy to your computer?
Did you install the FRC update?
How big was the file that you copied over?
Unread 18-02-2016, 10:41
How big was the whole directory under documents/LabVIEW Data that you needed to copy?
Unread 19-02-2016, 15:43
GuyM142's Avatar
AKA: Guy
The problem was solved!
I should have used File>Save as>Duplicate in order to "move" the project to the USB flash drive in order for it to work properly.
Unread 11-03-2016, 04:49
Amitai's Avatar
Amitai Amitai is offline
FRC #1577 (Steampunk)
Rookie Year: 2015
Amitai is an unknown quantity at this point
I'm having the same problem.
I used duplicate, but it still doesn't work. I tried all of the above.
The project was developed on one computer but it cant be opened on two other computers.
How can I fix this?
Unread 11-03-2016, 10:15
Originally Posted by Amitai View Post
How can I fix this?
The fix depends on what the problem is. How did you copy the project? How are you trying to open it? What exactly happens when you try?
Unread 12-03-2016, 17:33
Amitai's Avatar
Rookie Year: 2015
I saved the project on to a USB flash drive: save as -> duplicate.
Then I plugged the USD flash drive in a different computer and tried opening the project from the Getting started window -> open. Didn't work.
Then I tried opening the .lvproj file. Didn't work. All it does is open the getting started window.
I tried all of the above on another computer. Didn't work, same problem.
The three computers have FRC 2016 Labview software (Labview 2015 for FRC 2016).
Unread 22-03-2016, 11:01
Amitai's Avatar
Rookie Year: 2015
Any ideas?
Unread 22-03-2016, 11:15
Is the USB drive letter the same on the source and destination computers?
Unread 24-03-2016, 17:35
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
What files are currently on the USB drive?
