Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 19-02-2016, 13:52
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Hex broaching in thick aluminum stock
For reasons that are somewhat complicated we want to hex broach 1" aluminum square bar stock.
We have successfully broached thinner material.
Can someone please share knowledge about broaching in thick material and whether it is recommended?
Also we have access to either 6061 or 2024 so any advice on alloy for this purpose would be appreciated.
Because you are bound to ask, we are transferring torque from a hex shaft. Originally we were going to use square tube with laser cut inserts that had the hex shape. The issue that we are running into is compactness. Having external fasteners that hold the 'torque plates' inside of the tube is adding unwanted width to the mechanism.
Alan Gilgenbach
C.O.R.E 2062
Unread 19-02-2016, 13:57
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Hex broaching in thick aluminum stock
would the hex stock go through the walls of the tube in the original design? Or would the hex only insert into the laser cut insert?
If it goes through the walls couldn't you just allow the hex itself to locate the inserts? Then have them cut to fit snug inside the tube and be good?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 19-02-2016, 14:05
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
We have been broaching 1/2" 6061-T6 bar this year without a lot of trouble. I suspect we'd get through 1" as well, but haven't tried it.
Could you hold your inserts in place in the tube with tension pins, cut flush with your tube?
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 19-02-2016, 14:08
MisterG's Avatar
That's a good question. Originally there was a round clearance hole in the tube.
The tube was also .063 wall.
Maybe we could broach the tube (and go up to .125 wall if necessary).
I should remember my own advice: Never answer the question before you ask "What problem are you trying to solve?"
Alan Gilgenbach
C.O.R.E 2062
Unread 19-02-2016, 14:10
MisterG's Avatar
That's another good suggestion. We talked about that last night. We are/were worried about the ability to stay in the tube wall. (Again with thin wall tube.)
Alan Gilgenbach
C.O.R.E 2062
Unread 19-02-2016, 14:13
if you spread the load out enough 1/16" wall tube will hold up to a lot of force before failing. If I knew what you wanted to build, like I could actually see it I'd know for sure, but I think either of those options above would work.
As for broaching thick stock, you might have to flip your part over to remove the broach so you can clear the aluminum chips out of it so it won't get stuck on you. But it should work fine if your press is big enough.
Andrew Basse
Unread 19-02-2016, 14:15
RoboChair's Avatar
AKA: Devin Castellucci
I have successfully broached 2 inches of aluminum(6061) and brass(unknown) with an 8 ton arbor press. They were fully hex broached, not an over sized hole. It requires a LOT of force and a great deal of CARE. Watch the broach very carefully for any deflection and bowing and use stupid amounts of lube compared to normal.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 19-02-2016, 14:16
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
While some sort of insert would probably be better design wise I'm just going to comment on the broaching.
I've heard that it's recommend your broaching length doesn't exceed 2x your broaching diameter. So for 1/2 hex 1" would be the edge of that recommended range. However, 192 has done up to 1.5" long 1/2 hex in aluminum belt pulleys for our drivetrain without problems. This is done with cutting fluid on a hydraulic press. If you don't have access to a hydraulic press this may not be possible with an arbor press. There will obviously be higher loads involved as you'll have more teeth engaged at once so be extra careful the broach is kept straight. 6061 is probably the safer bet, softer should be easier to cut.
Unread 19-02-2016, 14:23
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
We use a push broach like this one to make hex holes for hubs and such. The material thickness rating on this one is 1/2" to 1-3/8". I know we have broached to the upper limit in 6061 aluminum before without issue, when making live shaft hubs for Colson wheels. In that case the hub was more like 2", and we counterbored each side some to limit our overall broach length.
I don't know what tooling you have available (push, rotary, or pull broach), or what the limits of other tools are, but with the push broach and a big arbor press, 1" aluminum bar should not be a problem. Just lubricate well and make sure the broach stays straight to the hole.
In regards to thin wall tube, we have gotten in the habit of plugging the ends of the tube with snug-fit delrin (or even hardwood) blocks, for 2-3", to give a larger bearing surface for pivots, or prevent tube crush where bolting on a sprocket. No reason you couldn't plug the end of a thin wall tube and broach through both the tube and the plug.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 19-02-2016, 14:32
MisterG's Avatar
That's the broach that we have. Seeing the 1 3/8" spec makes me feel better.
Alan Gilgenbach
C.O.R.E 2062
Unread 19-02-2016, 14:45
MisterG's Avatar
Joey,
Are you making the trip to Wisconsin this year? That's our home regional. Let me know if you guys need any help finding your way around etc. We'd be glad to lend a hand.
Alan Gilgenbach
C.O.R.E 2062
Unread 19-02-2016, 15:27
kbrowncny's Avatar
kbrowncny kbrowncny is offline
Mechanical Engineering Mentor
AKA: Kevin Brown
FRC #2168 (Aluminium Falcons)
kbrowncny is an unknown quantity at this point
I would recommend countersinking the aluminum it helps a lot.
Unread 19-02-2016, 15:57
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
For clarification
Can the broaching be done with a manual arbor press or with only a hydraulic press into the 1" stock?
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 19-02-2016, 16:02
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
We have a manual arbor press and broached 1" think 6061 AL this year without a problem. Does take some muscle but not too bad.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 19-02-2016, 16:11
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Could you it cut instead? Our waterjet sponsor had no issues cutting a 1/2 hex hole through 4 inches of 7075.
Don't know too much about broaching but if your still going to go your current route listen to everyone else above me.
