Re: Broken Code?
I would guess there's an issue with the Vision activation. We don't know what error you're seeing to know much more than that.
If you look for NI License Manager on your PC, you should see Vision Acquisition Software and Vision Development Module listed. There should be a solid yellow box under these. Do you see that? |
Re: Broken Code?
Yes I do see the yellow box
Re: Broken Code?
If you click the broken run arrow, it lists errors. What errors show up in that box?
I'd suspect "SubVI not executable" which will take you to the vision VI. Inside that VI, you'll have another broken run arrow. What errors do you see within this VI? Clicking on "Show Error" should take you to the point this error exists in your code. This will help figure out more about what you're seeing and how we can approach a fix. |
Re: Broken Code?
Re: Broken Code?
Be aware that the vision module doesn't start working after you activate it until you quit and restart LabVIEW.
