Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 19-02-2016, 17:08
Frc4741Rvhs Frc4741Rvhs is offline
FRC #4741
Frc4741Rvhs is an unknown quantity at this point
Rule on Perimeter Extension
Our robot will start within the frame perimeter but during the match it has the possibility extend past the 15 in extension rule. When everything on our robot is working correctly there will be no extra extension, but it could have the possibility to extend past the 15 in rule if it's not working correctly. Will we be penalized if the robot has the possibility to extend past 15 inches or will we only be penalized when the robot extends past 15 inches during a match?
Unread 19-02-2016, 17:14
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Rule on Perimeter Extension
The only penalty you will receive is that the inspector will tell the head ref that you have the potential to go more than 15" outside the FRAME PERIMETER. Then the refs will be watching you.
Only when we see an extension outside the FRAME PERIMETER will you get a FOUL. If it doesn't malfunction for you, no FOUL.
(since 2004)
Unread 19-02-2016, 17:41
Bob Steele's Avatar
AKA: Bob Steele
G18 ROBOTS may not extend more than 15 in. beyond their FRAME PERIMETER.
Violation: FOUL. If repeated, offending ROBOT will be DISABLED.
Unread 19-02-2016, 17:48
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Every time you go past your frame perimeter by 15" it could be a FOUL
FOUL is bad
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 19-02-2016, 19:36
Fouls are for actions, not for capabilities. You won't be penalized for having a robot that theoretically can overextend if it never actually does it.
Unread 20-02-2016, 00:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
FOUL is bad
Repeatedly going past your frame perimeter, you could be DISABLED.
DISABLED is worse.
Do whatever you reasonably can to mitigate this so that it happens rarely (or better, never) rather than commonly.
Unread 20-02-2016, 09:23
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
DISABLED is worse.
If the device is not working properly, Disabling the robot could save the team fouls, which may not be "worse"
___________________
- Tennyson, Ulysses
Unread 20-02-2016, 16:24
Bob Steele's Avatar
AKA: Bob Steele
The reason for the disable after repeated fouls is that, in theory, a team could just take the foul points as part of a strategy. The referee disable is there so that teams cannot take advantage of this.
Remember that if you disable your own robot, (self disable) fouls can still be called against it. Disabling does not stop fouls from being called.
In the case of a foul from a perimeter extension, you would initially be called for a penalty for an illegal extension even if you had disabled your own robot. and THEN you would be "disabled" by the referee which would stop further fouls for this rule (perimeter extension).
Self disabling would not necessarily rule out the first foul from being called.
