Go to Post Good judgement is the result of Experience. Experience is the result of Poor Judgement. - ChrisH [more]
Unread 19-02-2016, 18:47
Lesafian Lesafian is offline
AKA: Jeremy Styma
FRC #6077 (Wiking Kujon)
Rookie Year: 2016
Lesafian is an unknown quantity at this point
Losing Communications Code Issue?
We're having a major issue with our robot. We're constantly losing communications. It seems to mainly happen after going over an obstacle, but it also can happen from just turning too sharp.
I was getting an error spammed, it was something like RobotDrive... Output not updated enough. I added drive.setSafetyEnabled(false); to the teleop code to get rid of that.
There are no other errors besides that.
I've re imaged the radio a few times, but I have not re imaged the roborio. The battery is also fully charged.
I'm wondering if it's a programming issue, here is my code. Going to a scrimmage tomorrow so a quick fix Is really needed.
package org.usfirst.frc.team6077.robot;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Counter;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.VictorSP;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import edu.wpi.first.wpilibj.vision.USBCamera;
public class Robot extends SampleRobot {
    // Declarations
	RobotDrive drive;
	CameraServer camserver;
	Compressor compressor;
    CameraServer server;
    USBCamera camera1; //camera2;
	DoubleSolenoid claw, pusher;
	DigitalInput limit1;
	Counter counter;
	Joystick xboxController;
	Joystick logitech3dpro;
	VictorSP drivemotor1;
	VictorSP drivemotor2;
	VictorSP drivemotor3;
	VictorSP drivemotor4;
	VictorSP slideMotor;
	VictorSP armMotor;
	// Autonomous Names
	final String defaultAuto = "Default Autonomous";
	final String customAuto = "Autonomous Choice 1";
	final String customAuto2 = "Autonomous Choice 2";
	final String customAuto3 = "Autonomous Choice 3";
	final String customAuto4 = "Autonomous Choice 4";
	final String customAuto5 = "Autonomous Choice 5";
	final String limitswitchpress = "Limit Switch Pressed";
	// Chooser
	SendableChooser chooser;
	public Robot() {
		//Change values later
		drivemotor1 = new VictorSP(0);
		drivemotor2 = new VictorSP(1);
		drivemotor3 = new VictorSP(2);
		drivemotor4 = new VictorSP(3);
		compressor = new Compressor(0);
        server = CameraServer.getInstance();
        camera1 = new USBCamera("cam0");
        //camera2 = new USBCamera("cam1");
		drive = new RobotDrive(drivemotor1, drivemotor2,
				drivemotor3, drivemotor4);
		drive.setExpiration(0.1);
		xboxController = new Joystick(0);
		logitech3dpro = new Joystick(1);
		armMotor = new VictorSP(5);
		slideMotor = new VictorSP(4);
		claw = new DoubleSolenoid(0, 1);
		pusher = new DoubleSolenoid(2, 3);
		limit1 = new DigitalInput(0);
		counter = new Counter(limit1);
		chooser = new SendableChooser();
	public void robotInit() {
		compressor.setClosedLoopControl(true);
		compressor.start();
		chooser.addDefault("Default Autonomous", defaultAuto);
		chooser.addObject("Autonomous Choice 1", customAuto);
		chooser.addObject("Autonomous Choice 2", customAuto2);
		chooser.addObject("Autonomous Choice 3", customAuto3);
		chooser.addObject("Autonomous Choice 4", customAuto4);
		chooser.addObject("Autonomous Choice 5", customAuto5);
		SmartDashboard.putData("Autonomous Chooser", chooser);
	public void autonomous() {
		String autoSelected = (String) chooser.getSelected();
		System.out.println("Autonomous Mode selected: " + autoSelected);
		switch (autoSelected) {
		case customAuto5:
			break;
		case customAuto4:
			break;
		case customAuto3:
			break;
		case customAuto2:
			break;
		case customAuto:
			break;
		case defaultAuto:
		default:
			drive.drive(0.6, 0);
			Timer.delay(2.2);
			drive.drive(0, 0);
			break;
		Scheduler.getInstance().run();
	public void operatorControl() {
		while (isOperatorControl() && isEnabled()) {
	        //Default Camera Selection
			camera1.setFPS(30);
	        server.setQuality(50);
	        server.startAutomaticCapture(camera1);
			// Move robot using left and right joystick
			//drive.tankDrive(xboxController.getRawAxis(1), xboxController.getRawAxis(5));
			drive.arcadeDrive(xboxController.getRawAxis(1), -xboxController.getRawAxis(0));
			//Xbox Controller
			//Arm Motor Test With Triggers
			if (Math.abs(xboxController.getRawAxis(3)) > .1) {
				armMotor.set(xboxController.getRawAxis(3));
			} else if (Math.abs(xboxController.getRawAxis(2)) > .1) {
				armMotor.set(-xboxController.getRawAxis(2));
			} else {
				armMotor.set(0);
			// Move sliding mechanism forwards and backwards
			if (limit1.get() == true) {
				slideMotor.stopMotor();
				Timer.delay(0.25);
				slideMotor.set(-0.25);
				Timer.delay(0.5);
			} else if (limit1.get() == false) {
				if (Math.abs(xboxController.getRawAxis(5)) > .1) {
					slideMotor.set(-xboxController.getRawAxis(5));
				} else {
					slideMotor.set(0);
			//Logitech 3D PRO
			//Pusher Pneumatics System
			if (logitech3dpro.getRawButton(1)) {
				pusher.set(DoubleSolenoid.Value.kForward);
				claw.set(DoubleSolenoid.Value.kReverse);
				Timer.delay(1);
				pusher.set(DoubleSolenoid.Value.kReverse);
			//Claw Pneumatics System
			if (logitech3dpro.getRawAxis(1) > .1) {
			} else if (logitech3dpro.getRawAxis(1) < -.1) {
				claw.set(DoubleSolenoid.Value.kForward);
			Timer.delay(0.005); //Wait for a motor update time
			//Camera Switcher
			/*if (logitech3dpro.getRawButton(3)) {
				camera2.setFPS(30);
				server.startAutomaticCapture(camera2);
			} else if (logitech3dpro.getRawButton(4)) {
				camera1.setFPS(30);
	public void test() {
Unread 19-02-2016, 18:52
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Because it happens when subjecting force to your robot, I'd be more inclined to think it's a wiring issue. Try watching the status lights on your RIO/radio as you lose coms. Do you see it reboot? Can you jiggle the wires and cause a reboot?
Unread 19-02-2016, 19:00
Chris Mounts's Avatar
Chris Mounts Chris Mounts is offline
FRC #1188 (Oaktown Crewz)
Chris Mounts is an unknown quantity at this point
Re: Losing Communications Code Issue?
Take a look at this thread: http://www.chiefdelphi.com/forums/sh...hreadid=143892
Lot's of possible reasons.
Unread 19-02-2016, 21:05
Do you really want to do the camera1/server initialization every time through the operatorControl() loop?
I'm pretty sure you do not want to put all those Timer.delay() calls in there. Every time you activate your pusher, or your slide limit is hit, you're going to stall the code and lose communication. If you need to do timed sequences like that, they need to go in a parallel task outside the loop, or you need to implement them as a state machine that checks the clock to know when to step to the next state.
