Go to Post You will "generously donate" your game pieces into your opponent's goal. - johnr [more]
Unread 19-02-2016, 12:33
alambert14's Avatar
alambert14 alambert14 is offline
Student Programmer
AKA: Abby Lambert
FRC #2035 ("Rockin" Bots)
alambert14 is an unknown quantity at this point
Wiring Multiple PCMs
Our team is using lots of pneumatics this year, enough that we need 2 PCMs on the robot. There was not enough room on the power distribution board to wire 2 PCMs and a VRM, so we split the wires for one to power both of the PCMs, which may be problematic considering most people say that each PCM has to be on its own circuit.
However, even if we can power them both, we do not know how we would wire the CAN wires to the power distribution board, considering there are only two spots to connect CAN wires (one for the roboRIO and another free one). We can't split those wires because we need to talk to each PCM individually with the code.
If any of you guys have been able to pull this off, could you let us know how you wired it? Worst case scenario we can always get rid of two of our solenoids and split the air instead (bringing us back down to 1 PCM), but we would really like to have 2. Thanks!
Unread 19-02-2016, 12:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Wiring Multiple PCMs
CAN is wired in series, you just put the additional PCM in the chain...it has two places to put pairs of wires.
Unread 19-02-2016, 12:51
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
Make sure that each PCM has its own CAN ID.
https://wpilib.screenstepslive.com/s...ribution-panel
The solenoids on the second PCM need to use the second CAN ID.
Unread 19-02-2016, 12:57
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
As a team that's using two PCMs, I can tell you that powering them on seperate circuits is required by the rules (on mobile so I can't quote the specific one but trust me.) We're wiring the second PCM to one of the smaller wago ports on the PDP with a 20 amp breaker, which I believe is the only legal way to do it.
As for CAN, it's a bus. Wire from the roboRIO to the first pair of ports on 1 PCM, use the second pair of ports to wire to the second PCM, which then goes to the PDP.
Unread 19-02-2016, 12:59
alambert14's Avatar
Student Programmer
AKA: Abby Lambert
But don't you need a spot to wire the roboRIO as well? Or is there somewhere else it can go?
Unread 19-02-2016, 13:06
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Roborio has its own spot. Pcm2 attaches to a regular wago port like your motors
If your question is about canbus:
Roborio -> pcm1 -> pcm2 -> pdp
Unread 19-02-2016, 13:08
alambert14's Avatar
Student Programmer
AKA: Abby Lambert
Got it thank you so much!
Unread 19-02-2016, 21:53
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The order does not matter for CAN. You can also put the PCMs after the PDP on a bus as short as an FRC robot.
Kettering Motorsports
Unread 19-02-2016, 23:00
True, but then you would have to remove the terminating resistor on the PDP (jumper), and then put on a terminating resistor on the last item in the link. I don't know what the specs are for the terminating resistor, hence put the PDP at the other end from the roborio.
On a can bus as short as the FRC robot, you could get away from best practices. But, they make it easy for a team to be compliant, so why not?
Unread 20-02-2016, 00:20
apalrd's Avatar
More Torque!
VRC #3333
At high speed (1mbps), the recommended max bus length for CAN is 40 m. At this length, the actual electrical design is important and two 120 ohm resistors (one at each end) are a must.
CAN also allows for unterminated stubs from the bus, at 1mbps the recommended length without any electrical design thought is 0.3m. With careful design this can be increased, on a full-length bus.
A FRC CAN bus with only a roboRIO, two PCM's and a PDP could be below the recommended length for an unterminated stub. You definitely need at least one resistor to pull the bus to a recessive state, but the entire bus should be below the length where reflections are significant (~2m). It's also likely that the length after the PDP could be less than 0.3m and be within the spec for an unterminated stub.
tl;dr CAN is very tolerant of non-ideal bus layout if the wires are relatively short.
