Go to Post Surprise! There is no ideal alliance. As soon as you think you have a winning strategy, someone WILL figure out how to beat it. - Tom Bottiglieri [more]
Unread 19-02-2016, 22:23
Wes2443's Avatar
Wes2443 Wes2443 is offline
AKA: Wesley Sakutori
FRC #2443 (Blue Thunder)
Wes2443 is an unknown quantity at this point
How to wire CIM Coder(am-3314)
The diagram seems to be telling us to wire it with a 12v supply for the pull up resistors, but that seems wrong.
Unread 19-02-2016, 22:34
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: How to wire CIM Coder(am-3314)
The datasheet says it can be supplied with 4-24v nominal and that the pull up voltage should be the same as the supply voltage.
You should probably power it off off of the 5v sensor supply available from the DIO pins. The DIO pins already have a suitable pull-up to 5v internal to the roboRIO.
Kettering Motorsports
