Go to Post Ahem......"where are the President's safety glasses???" - Travis Hoffman [more]
Unread 20-02-2016, 01:08
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
Intake Ideas PLZ !!!!
Our team is doing a intake/shooter coming from the front of the robot. The robot come in and shoots out the same way but we dont have a carrier for the ball whats a good design to keep the ball in.
Ps
The intake is two wheels sort of like a tennis ball launcher
Unread 20-02-2016, 02:09
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Intake Ideas PLZ !!!!
There's plenty of resources out there. There's the Robot in 3 Days (Ri3D) videos on youtube. There's plenty of robot reveals on Chief Delphi too.
That said, your ball carrier will probably depend on your shooter. For example, a catapult shooter is probably its own ball carrier.
Unread 20-02-2016, 06:51
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Maybe this will help. We built a similar shooter to what you described during Ri3D. PM me if you want to know dimensions.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 20-02-2016, 09:39
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Our launcher just "carries the ball", so we figured out how to hold it more securely while crossing the defenses. If your intake contacts both sides of the boulder as it brings it in, you may be able to do something like this: We have a photo range detector looking at our intake. While in intake mode we stop the intake wheels while the ball is wedged between the rollers and the back plate. We cross defenses with it wedged in there. When we're getting ready to shoot, we follow through on the intake and feed it into the launcher. Driver controls for this are still a work in progress.
Unread 23-02-2016, 23:02
rookierunner's Avatar
rookierunner rookierunner is offline
FLL / FRC Mentor
AKA: Tom L.
FRC #2340 (Xcentrics)
rookierunner has a spectacular aura aboutrookierunner has a spectacular aura about
We don't have much of a 'launcher' per se. It is more of a depositor. We reverse the acquisition rollers to eject the boulder. The clever part of the system is that when the boulder is fully seated it trips a switch wired into the Talon as a limit switch automatically turning the motor off. No software required... But we did add some java code to display the state of the limit switch on the driver station.
Good luck.
