Go to Post 30 point hang is brutal. Those who say it is easy are not thinking it through or are way smarter than the rest of us ... - Paul Copioli [more]
Unread 02-20-2016, 01:25 AM
CyberTeam5713 CyberTeam5713 is offline
FRC #5713
CyberTeam5713 is an unknown quantity at this point
PLZ Help
How do I program a Xbox Controller so that the left analog drives foward/backward and the right analog turns the robot left/right
Unread 02-20-2016, 10:14 AM
Re: PLZ Help
   * Arcade drive implements single stick driving. This function lets you
   * directly provide joystick values from any source.
   * @param moveValue The value to use for forwards/backwards
   * @param rotateValue The value to use for the rotate right/left
   * @param squaredInputs If set, decreases the sensitivity at low speeds
  public void arcadeDrive(double moveValue, double rotateValue, boolean squaredInputs) {
