Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 20-02-2016, 10:25
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is an unknown quantity at this point
Re: CAN follower mode
We are having a similar problem.. can't get slave/follower talon to work follow masters. Individually the talons all work if we make them masters. All fw is up to date. Don't see any faults in web ui. We tried steps in sw manual section "16.31.3. Confirm Slave/Follower Talons are driving ". When the master is output signal, the follower is doing nothing. We don't see leds change from solid orange. We use smartdashboard to change the follower to be in percentvbus mode and talon works fine. When talon is in follower mode, the webui self-test shows mode as "mode 5 follower". All this used to work and we aren't sure what may have broken it. Any ideas what to check next?
Thanks.
-Maciej
