Go to Post ah, common sense, not as common as one might think... - Ansem Retort [more]
Unread 20-02-2016, 11:10
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
Denso Motors on the Power Distribution board
yes, i should be able to find this on the web, but i can't.
does anyone know what amperage breaker you need to use on the denso window motors? what slot in the power distribution board they go in? what will pass inspection?
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
Unread 20-02-2016, 11:30
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Denso Motors on the Power Distribution board
I have no idea the maximum amperage of the denso window motor.
What ever slot you want that has a breaker of the amperage you want.
Inspection only checks on proper wire size for a given breaker amperage. Inspection does not check whether you can burn out your motor by giving excess amperage, or fry your custom circuits with too much voltage (feeding 12 volts to a 5 volt circuit).
Unread 20-02-2016, 11:59
The Denso window motors draw 20 to 21 amps depending on the handedness, so a 20a breaker would work.
