Go to Post The name of the game will be "Conjunction Junction". The robots will be tasked with hooking up words and phrases and clauses. You're welcome. - Travis Hoffman [more]
Unread 20-02-2016, 16:36
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
green and yellow necessary for can wire?
Is there a rule saying that its necessary to use green and yellow wire to extend can wires? Or will red and black be just fine?
Unread 20-02-2016, 17:08
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
Re: green and yellow necessary for can wire?
Green and yellow are the conventional colors for CAN.
I'd stay away from red and black, or other colors designated for plus and minus d.c. voltages in the rules, though that's more to avoid confusion than a safety issue. It is easy enough to come up with a short amount of wire of other colors and it will make your Robot Inspector happy. Never a bad thing.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 20-02-2016, 21:49
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
Green and yellow wire does nothing different than any other wire. The important thing about it is that it is twisted. Some teams twist their own wire using a drill.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 20-02-2016, 22:17
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
No I was just asking, because i wasn't sure if there was a regulation that stated it should be green and yellow so that the inspectors know what its for. I am aware that the wire itself isn't different .
Unread 21-02-2016, 01:18
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
...and of you do, make sure the ends can pivot. Otherwise you'll twist the wires too (not just the pair) which will warp, split, and break the wires.
Unread 21-02-2016, 01:55
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
My PDF viewer has a nice search function. It found 8 occurrences of "green"; none of them had anything to do with wires. There were 55 occurrences of "yellow"; the only hit related to wire colors was in R51.
Mentor http://www.teamtitanium.org/
Unread 21-02-2016, 02:40
ratdude747's Avatar
AKA: Larry Bolan
So... Legal, yes (presumbly). Recommended, not really.
Unread 21-02-2016, 08:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Realize the your RI is not going to buy off on "I read it on Chief Delphi" So you need to learn how to support your robot rules compliance by referring to the manual. Wire requirements for Canbus should be somewhere in the controls section. Since it is not there and it is hard to prove a negative, you should respectfully ask which rule requires a specific color for CanBus.
While it makes sense to use wire colors that different from power wiring, there is no rule requiring it.
