Go to Post "my life is incomplete, my nose has lost the imprint of my safety goggles." - Nin_estarSaerah [more]
Unread 20-02-2016, 13:58
chadbartel chadbartel is offline
None #1339
chadbartel is an unknown quantity at this point
WCP Spartan Sensor Board
We're attempting to use the WCP Spartan Sensor Board this year and we've run into a low voltage issue on the DIO ports when mounted to the cRIO, reading about 1.8 Vdc. Has anyone else seen this problem? Also, has anyone had success using the board and gyro?
Unread 20-02-2016, 15:08
AustinSchuh AustinSchuh is online now
Re: WCP Spartan Sensor Board
You got luck that I was checking Chief today. I designed the board. Please mail me at austin.wcp on boardsailor.com so I can get you more prompt help. I check that a lot more often.
Are all 3 LEDs on? Where are you getting power for the board from? Please email me a picture.
I personally tested all the boards that shipped and made sure that the gyros worked.
Austin
Unread 20-02-2016, 15:11
Also, did you mean roboRIO instead of cRIO?
Unread 20-02-2016, 16:41
Justin Ridley Justin Ridley is offline
FRC #0118 (Robonauts)
Justin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond reputeJustin Ridley has a reputation beyond repute
Send a message via AIM to Justin Ridley
We saw this exact problem. Traced it to some incorrectly wired sensors. Double check that none of your sensors are sending 5V to ground. We pulled sensor wires one by one till we found the problem.
-- Justin Ridley --
19 years
27 --> 221 --> 857 --> 118
Unread 21-02-2016, 00:58
Thanks Justin!
Chad and I exchanged emails and there was no power being applied to the board. He's back up and running!
