#10
Re: Week 0 Discussion
Over here at team 3102's Week Zero the competition itself was exceptional, and we got the process going smoothely to make it great for everyone.
The Problems: We were using FMS Offseason Only about half of the OM5P routers there would configure properly, even with firmware flashes. We could take one router, configure it fine, take another, wouldn't work. Even three computers wouldn't do it when it did others fine, then randomly after trying all day it would work. Unreliable at best. We had to borrow out a few older D-links B's to teams, and those configured perfectly every time. Teams CAN NOT connect to a central router to practice with their robots. Teams were controlling other teams and seeing other cameras, and we made sure to re-configure their routers to their proper team numbers. I was told that the DNS method implimented in FRC's software does that natively. With FMS software enabled we could get two robots working correctly but didn't have time to do more testing. This ruined our entire FMS setup because there was no time to take everyones radio's and re-configure them, especially not with the configuration problems. The solutions: Teams were told to reconfigure their own routers with the config software, so we had about 11 seperate AP's going. Much interference with our stream was had, however teams could operate properly. We simply had teams use the 'practice' method and set their timing to: 0 15 0 115 20 I had to do a good 30 laps around the field overall, showing teams before every round the timing and to press enable practice when we do a ready check and count down. Next Year: Next year if the same issues persist we will simply inform teams to configure their own radios, then right before lunch we'l gather them up and configure them while lunch goes on. Then we should be able to control them via FMS for official rounds. We will also be running a dedicated line to have a consistent live stream, another camera may be added. Thank you to those that came We greatly appreciated the crowd we drew. Solving problems and getting everyone operational was a tedious, but very rewarding task. Its really great seeing all of you compete on the field and testing out your equipment. Sorry about the music, nobody thought to hire a DJ This is our first year with our official Andymark field, next year we'l try to make it all just right. |
