Go to Post The championship could be in a swamp infested with flying insects, and it would still rock the world :D - kristen [more]
Unread 27-01-2016, 17:16
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Java OpenCV on Jetson Tk1
We recently started to use our Jetson that we got a while back to do vision tracking this season. We built a jar to start doing some vision tracking, we ran it on Windows first to see how it would run, and it ran great. We used an openCV library in our project. We then transferred the executable .jar over to our Jetson, and it wouldn't run, with the error:
java.lang.UnsatisfiedLinkError: no opencv_java310 in java.library.path
We tried running it as a relative path, using the java.library.path file, and putting the opencv jar inside the following folders: /usr/include/ /home/ubuntu/ and the project folder. We also tried to load the file as a static (explicitly stating the path), but with no luck either. We also tried reinstalling the libopencv from apt-get and getting the one from the JetPack installer.
What can we do to use an OpenCV library in our Java project and run it on our Jetson Tk1 (running ubuntu)? Do we need to build a library on the Jetson itself? How do we do that?
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 27-01-2016, 17:25
Turing'sEgo Turing'sEgo is offline
Turing'sEgo is on a distinguished road
Re: Java OpenCV on Jetson Tk1
Did you add it into the external libraries in your project?
Unread 27-01-2016, 17:31
lethc's Avatar
#gkccurse
AKA: Becker Lethcoe
Yes, we added the openCV .jar library to our build path in our project
Unread 27-01-2016, 17:45
Jared's Avatar
Jared Jared is offline
The openCV library is loaded as a native library in java, so you need to have both the openCV jar and the openCV library in your java.library.path.
You could either build openCV on the Jetson, or possibly find a precompiled version for your device.
Unread 20-02-2016, 20:44
lobrien lobrien is offline
FRC #3880
Rookie Year: 2016
lobrien is an unknown quantity at this point
Has anyone gotten this to work? It's driving me crazy -- System.loadLibrary(Core.NATIVE_LIBRARY_NAME); executes successfully but when I attempt to access any OpenCV functions I get the linker error. I've even used nm to confirm that the .so is exporting the symbols.
I've been building OpenCV from scratch because I have not been able to get OpenCV4Tegra to install. Working with opencv-3.1.0. I know that at least the C/C++ aspect is working properly -- it's building those test applications and they run properly.
Unread 21-02-2016, 13:18
FRC #3880
Rookie Year: 2016
So, just for the record: finally got it to work by completely rebuilding from scratch and... *poof!* ... the seemingly-same library in the same location suddenly worked.
