Go to Post We're still not ready for 2012.... - AdamHeard [more]
Unread 02-20-2016, 08:26 PM
StewEsho's Avatar
StewEsho StewEsho is offline
Programmer
FRC #4940 (KnightVision Robotics)
StewEsho is an unknown quantity at this point
Limit switches are always on.
Our team is having a difficult problem with the limit switches. While they used to work, earlier today they stopped working correctly and always returned a "true" value, regardless of whether they were pressed or not. We tries rewiring in every possible way, we tried adding the most basic limit switch code into a sample program, we tried looking online for solutions, but nothing works. Does anyone know what the problem could be?
Information
Here is the source code for the sample program we tried running (comments and all):
https://gist.github.com/StewEsho/68871eb0a2c541ee2b07
Here are the images of the wiring (just looking at the wire for the switch in port 1, but all switches have similar problems):
http://imgur.com/a/c02fV
When testing, we tried printing the outputs from all ten ports, even the ones with nothing plugged in, and they all returned "true".
Shortly before this problem arose, we couldn't run the robot and the driver station said "Brownout Error". We were forced to power cycle the robot to continue use. Could this possibly be related to our issue?
All other motors, speed controllers, and encoders work perfectly fine.
Thank you in advance for your time and your help!
Unread 02-20-2016, 08:35 PM
Re: Limit switches are always on.
Have you tried unplugging the limit switches and testing them with a multimeter?
Unread 02-20-2016, 08:40 PM
StewEsho's Avatar
Programmer
Yes, we tried using a multimeter and the switches seemed to work just fine.
Unread 02-20-2016, 08:51 PM
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The inputs pull high (true) when not connected. You need to ground the signal to make it false. The switch should be connected to the white and black.
Unread 02-20-2016, 09:24 PM
StewEsho's Avatar
Programmer
Yes, that solved the problem. Thank you so much!
Unread 02-21-2016, 09:05 PM
Originally Posted by FrankJ View Post
you need to ground the signal to make it false. The switch should be connected to the white and black.
So... someone on your team played a prank and changed the wiring while you weren't looking?
