Go to Post May we always remember those who have shaped our lives for through us they shape those around us. - mechanicalbrain [more]
Unread 20-02-2016, 20:43
Caitlinnnnn99's Avatar
Caitlinnnnn99 Caitlinnnnn99 is offline
Why does bag come so soon?
AKA: Caitlin T-HB
FRC #3250 (Kennedy Robotics)
Caitlinnnnn99 will become famous soon enough
Rhino Tread Delamination
After driving our robot around for a couple hours we noticed that the tread started to delaminate from the belt. Is anyone else having this issue? If so, any recommended solutions? Does anyone know if AndyMark warranties this product?
Name:	Rhino Tread Delamination.jpg
Unread 20-02-2016, 20:49
Bluman56's Avatar
Bluman56 Bluman56 is offline
Mentor Without Borders
AKA: Nikita
FRC #2579
Bluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the roughBluman56 is a jewel in the rough
Re: Rhino Tread Delamination
I believe 3044 also had this problem but they sourced their belts from Brecoflex. Might be a universal issue? Not sure. I hope this gets figured out especially since we are also using the rhino drive.
Unread 20-02-2016, 20:51
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Contact andymark. Call them and email them. They have great customer service, and will more than likely work with you to make you whole.
Unread 20-02-2016, 20:52
You may want to send AndyMark an email. Be detailed about the problem; any information that you think might be useful should be included (runtime, tension, possibly storage conditions).
AM is FAST at responding.
Unread 20-02-2016, 20:53
dradel's Avatar
But then I looked closer at the pic, and see the non andymark pulleys.
Unread 20-02-2016, 21:12
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Shouldn't matter if it was an AM belt.
Unread 20-02-2016, 22:04
dradel's Avatar
I agree. And now that I think about it probably won't matter to am.
Unread 22-02-2016, 09:04
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
We have seen a couple of cases of this de-lamination. I have spoke with the supplier of these belts, and here is their recommendation:
  • They use a rubber base cement that has great bonding properties to adhere the tread (roughtop carbox, in this case) to the urethane timing belt material.
  • Your customer can contact any 3M or Loctite distributor and find a good adhesive for rubber to rubber adhesion.
  • The main thing is to clean both surfaces and let the solvents evaporate and bond according to the directions.
  • It will need to be clamp off with normal pressure to get the curing out and good bond.
I hope this helps. Another team is trying out "Gel Control CA Super Glue" from LocTite. We will try the same thing, or something similar early this week.
Andy B.
Unread 22-02-2016, 10:29
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Sorry to contradict you, but I respectfully disagree.
It's the same reason people void warranties on all sorts of things. You can't purchase a component from a manufacturer, use it clearly outside of the intended use case (in this situation, not using the appropriate pulleys) and expect a product to be warrantied.
Kudos to AM for exploring a solution even though this is the case.
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
Unread 22-02-2016, 12:15
ratdude747's Avatar
AKA: Larry Bolan
I see your point although I'd point out that the pulleys (at least in the picture) look to be larger which would create less flex which in turn should make the belt less likely to de-laminate.
Also, a lot of AM products are intended for custom installation; the warranty is good, as long as you don't modify the product or do something obviously dumb (like we did in 2010 to that poor AM2's dog gears).
If you look at AM's listing, they mention having pulleys that are specifically designed for the belt, but nowhere do they say that the pulleys are the "intended" use of the product. I personally interpret that to mean that as long as you're not abusing them, for warranty purposes, you're covered.
I do agree that it is nice that AM goes to so much trouble to investigate reported issues.
Unread 25-02-2016, 10:43
Mr. Ackroyd's Avatar
Mr. Ackroyd Mr. Ackroyd is offline
FRC #3044 (OxBe4)
Mr. Ackroyd is on a distinguished road
Team 3044 here.
we did have the same issue but the belts were sourced from BrecoFlex. The problem turned out to be the result of a large influx of orders by FRC teams and the company was pulling all stock they had on hand to get orders out. This in turn weakened their manufacturing process and the belts we not heat welded long enough.. The company was great to work with and they sent new belts free of charge.
It looks like a similar issue where the belts were not heat welded long enough. I would recommend finding spares for competition. Once the delamination process began, it was a matter of ten minutes before the belts came off the treads..
good luck and i hope the re-gluing works
Unread 29-02-2016, 22:51
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Any word on if the glue is holding for these?
Unread 15-03-2016, 13:46
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Because it hasn't been mentioned yet, Brecoflex told us that shoe goo is supposed to work really well if you are using rubber backings.
Unread 15-03-2016, 14:14
FRC #1747
No issues with out AM sourced belts and pulleys through 19 very, very competitive district matches.
