Legality of stepstool
From my week 0 experience, the drawbridge is a terrible hindrance to the drivers' line of sight. But it's almost short enough to see over. If I were six feet tall, the view would be quite better.
Would it be illegal to bring a stepstool or platform for drivers to stand on during a match? I don't seem to recall any rules prohibiting that, but if legal, it may be useful under certain circumstances. |
Re: Legality of stepstool
I think this would be certainly fine. Seeing as the rules only prohibit powered devices or vision-impeding things, a stepstool should be fine, as long as it isn't powered. Not that I can think of a way you could power it
. Also, seeing as the GDC says ok (jokingly, but still) to baguettes and turkey legs, this should definetly be fine. |
No, see rule T26-1:
FRC4522 asked something similar on Q&A just now.
Now taking bets on whether the GDC will say "No per T26" or "We think the answer to QXXX answers this question. If it does not, please rephrase and ask again." |
T26-1 clearly allows for the use of a step stool...
D. TEAM STANDARDS and devices, if needed, to assist placement in the Standard Holder E. special clothing and/or equipment required due to a disability D. Allows you to bring a step stool to place your standard and does not require you to remove it from the driver station E. Allows you to bring a step stool provided the ref's agree that being short is a direct hindrance on your ability to play the game Also I noticed someone has already submitted it to the Q/A so we will know for sure soon. |
#7
I think you can consider this a "signaling device" or an assist to a vertical height disability.
#8
First, that item is "if needed" on the standard. Driver's station is roughly 6.5' tall. MANY people can reach that high without much effort--slap the sill of a normal doorway, you're probably good. Reaching that high with a standard might be a bit more difficult, but should be doable. Second, if you are ACTUALLY disabled by being short (as in, short enough to trigger ADA--there are, in fact, regulations on this), then you can make the argument that you need the stool (though you might get the wheelchair ramp instead). However, if you're just "not tall enough to see the field", that is NOT a disability! If, for example, someone under 5' is on the drive team, they'd probably have a good case for the stool. If the entire drive team is over 6'? Not a chance. And also, I should remind you guys: SPY. Use him/her. |
#9
If passive assistive devices are allowed, we are totally bringing these:
#10
Our team had this idea, I am pretty sure we are going to use this.
https://frc-qa.firstinspires.org/Que...ring-the-match Quote:
Funny you cannot have a periscope, but you can have the electronic equivalent
#13
Having a periscope around your face blocks your vision, which is a safety hazard.
#15
Category C, it is an announcing stand for your town crier(driver) to better keep with the medieval theme. Make it look nice.
