Go to Post By inviting engineers and mentors to be a part of your team and partnering with them...brings added value, depth, strength, expertise, and wisdom to the team and to the overall experience. - JaneYoung [more]
Unread 20-02-2016, 12:34
rjain's Avatar
rjain rjain is offline
FRC #5549 (Gryphons.EXE)
Rookie Year: 2015
rjain is an unknown quantity at this point
Problems installing FIRST Robotics Utilities
Hello All,
I am trying to install the FRC 2016 Update suite and I am getting error 1304, Error writing to file. I am running the installer as admin. Everything else installs fine. Is there any way to fix this. I have tried a complete removal and re installation of NI software but that did not work. Thanks in Advance!
Unread 20-02-2016, 22:52
Re: Problems installing FIRST Robotics Utilities
Do you have any antivirus programs running that you need to disable before running the setup program?
Does the error message tell you which file it is unable to write?
