Go to Post Thank you FIRST -- thank you, thank you, thank you -- I can't say that enough. We can't say that enough.... Its too bad that more of us don't try. - Aidan F. Browne [more]
Unread 20-02-2016, 17:02
parkerthenoob parkerthenoob is offline
FRC #4495
parkerthenoob is an unknown quantity at this point
Question SampleRobot Teleop Issue -- Help
Our team is using the SampleRobot Template for C++ and we're trying to drive our robot in teleop with arcade drive. We just opened the SampleRobot file and, without making any changes, ran the robot in teleop mode.
Unfortunately, the robot will only go forwards/backwards and won't turn left or right. Any ideas?
Thanks.
Unread 20-02-2016, 23:35
Re: SampleRobot Teleop Issue -- Help
Look at the Driver Station's USB setup tab. Verify that the controller axes you're using match the ones in the robot code.
Unread 21-02-2016, 00:59
FRC #4495
Thanks!
Unread 22-02-2016, 11:49
FRC #4495
I looked at the axes in the Driver Station and everything appears to be working, but where in SampleRobot should I look for the axes?
Thanks.
