Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 21-02-2016, 01:12
kingnyancatjack's Avatar
kingnyancatjack kingnyancatjack is offline
AKA: Tommy Zhu
FRC #2605 (Seamonster Robotics)
kingnyancatjack is an unknown quantity at this point
Vision With GRIP
We have this code, but can't figure out why it doesn't work.
import wpilib
import networktables
from networktables import NetworkTable
class Vision():
def __init__(self):
# NetworkTable.setIPAddress("10.26.5.73")
# NetworkTable.setServerMode()
self.table = NetworkTable.getTable('GRIP/myContoursReport')
def printCenter(self):
self.centerX = networktables.NumberArray()
self.center = self.table.retrieveValue("centerX", self.centerX)
print("Center: " + str(self.center))
Please help.
Unread 21-02-2016, 13:21
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Vision With GRIP
NetworkTable.getTable("/GRIP/myContoursReport")
also, next time, use [code][/code] tags
Unread 22-02-2016, 21:24
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Originally Posted by Arhowk View Post
We are suffering from the same problem with the exact same code. Here is a more verbose description of what is happening:
retrieveValue
    raise KeyError(name)
KeyError: '/GRIP/myContoursReport/centerX'
Locals at innermost frame:
{ 'entry': None,
  'externalData': [],
  'name': '/GRIP/myContoursReport/centerX',
  'self': <networktables2.server.NetworkTableServer object at 0x1027b6c18>}
Thanks!
Unread 23-02-2016, 00:39
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
The first thing that I would recommend is using table viewer to ensure that the value is actually available. And, even if it's not available, the retrieveValue API doesn't have functionality to set a default value, so you should do one of two things:
  • Set a default value when your program starts up
  • Surround the retrieveValue() call with a try...except block
Finally, I tested the functionality, and you can use pynetworktables to retrieve a NumberArray. However, the retrieveValue function returns None, not an array. Therefore, the code you have above won't work -- but remove the assignment, and it should be fine:
table = NetworkTable.getTable('/GRIP/myContoursReport')
na = NumberArray()
try:
    table.retrieveValue('centerX', na)
except KeyError:
    # do something else here...
else:
    print(na)
Unread 23-02-2016, 23:19
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Oh, I didn't see that quirk in the code (kids- always format your code in code blocks)
retrieveValue works like alot of C functions where it requests a pointer to put data into rather than returning the data itself (for reasons). The first argument is the name of the key (similar to how youd use getNumber(key,default)). The second argument isnt the argument but rather the variable that the return value will be placed into.
Unread 01-03-2016, 22:25
team-4480's Avatar
Debug? What's that?
FRC #4480
I now have the problem of connecting to GRIP. GRIP seems to be the server and in order to access the variables, you need to use the ClientMode. The problem with that is you need the IP of the server. GRIP is going to be running on our Driver Station and the IP will not stay the same.
How am I supposed to connect to GRIP?
Here is the working code(Just using GRIP locally by setting both to 127.0.0.1):
import sys
import time
ip = "127.0.0.1"
NetworkTable.setIPAddress(ip)
NetworkTable.setClientMode()
NetworkTable.initialize()
default = networktables.NumberArray()
while True:
    try:
        table.retrieveValue('centerX', default)
    except KeyError:
        pass
    else:
        print default
    time.sleep(1)
Thanks!
Unread 01-03-2016, 22:27
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
GRIP is a client. The server should be your roboRIO.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 01-03-2016, 22:29
team-4480's Avatar
Debug? What's that?
FRC #4480
When I use Network Table Viewer to see the values, I need to click "Client" in order for it to work. "Server" never finds the table.
Unread 02-03-2016, 00:15
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Correct, because the roboRio is the server. Clicking "Server" makes the Viewer its own server.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
