Go to Post I love first because of the late nights, the unparralleled stress, the excitement, the emotion. Because of the close defeats, the close victories. Because of the pride, the sense of accomplishment, the feeling of embettering the world. But most of all, because of you, the other teams. - Keith Chester [more]
Unread 21-02-2016, 12:22
tyler9698's Avatar
tyler9698 tyler9698 is offline
AKA: Left Hook
FRC #5624 (Tiger Tech)
tyler9698 is an unknown quantity at this point
Robot loses communication while going over obstacles
When my team drives our robot everything works fine. When we drive over obstacles we lose communications. We checked all of our wires and we detected no problems. Does anyone know any other reasons why this would occur.
We think it could possibly be a brown out issue, but we are unsure how to solve it.
Unread 21-02-2016, 12:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Robot loses communication while going over obstacles
Router browns out with multiple CIMS driving WCD
A lot of good info in the above thread.
Dr. Joe J.
Team #88, TJ2
Unread 21-02-2016, 12:46
boz336 boz336 is offline
Electrical Engineer/Mentor
FRC #1599 (CircuiTree)
boz336 is an unknown quantity at this point
We had the same problem last year. It was a very slightly loose crimp on our battery lug. We thought our wiring was fine.. And the behavior wasn't repeatable when we shook the robot off field... But consistently happened when we drove over the platforms.
You might want to triple check the connections to the battery and/or other power connections that "look" OK, but might be intermittent under mechanical shock. You can always try the shake test... But in our case we still didn't see the problem.
If you really suspect brownout, you can look at the robot logs for battery voltage to see if it gets low.
Very frustrating... Hope you get it solved.
Unread 21-02-2016, 13:34
TheFox2996 TheFox2996 is offline
AKA: Ben Fox
FRC #2996 (Cougars Gone Wired)
TheFox2996 is an unknown quantity at this point
Multiple teams were having the same problem at our scrimmage yesterday including ourselves. We discovered that the bridge power connector can sometimes wiggle loose during a match and cause the bridge to reboot when it experiences some shock from an obstacle. We fixed ours with a ziptie stretching around our bridge to hold the power connector tightly in place.
Unread 21-02-2016, 13:40
Steven98's Avatar
Steven98 Steven98 is offline
AKA: Steven Crosby
FRC #2386 (The Trojans)
Steven98 is an unknown quantity at this point
Our team had the same problem. For us, it was just a loose roboRIO power wire that wouldn't stay in the PDP (though it looked like it was fine).
A lot of possible solutions were posted in a similar thread about a week ago; it's probably worth a read: http://www.chiefdelphi.com/forums/sh....php?p=1540609
Unread 21-02-2016, 19:21
AKA: Dr. Joe
FRC #0088 (TJ2)
All closely related threads:
Power draw issues
Battery Voltage problem
Voltage Drop issues
Team #88, TJ2
