Go to Post You'd be surprised how many teams don't read the rules period. - Koko Ed [more]
Unread 21-02-2016, 13:33
mypie4050's Avatar
mypie4050 mypie4050 is offline
AKA: Micah Young
FRC #4050 (Biohazard)
mypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nice
Exclamation Voltage Drop issues
When testing our robot recently, we encountered an issue where we received a significant drop in battery voltage, and therefore a drop in performance and a loss of control. This occurred whenever driving the robot on carpeted floor, particularly when turning and when crossing defenses. We experienced the problem on two particular occasions. The first was after a prolonged period of driving (over defenses and on carpeted floor). The victors controlling our drive train were rather warm. We assumed they had overheated.
The second occured on our first test after enabling the braking function on the Victors. To sum it up:
The Robot:
6 pneumatic wheels from AndyMark on the AM14U3 chassis
4 CIM motors, 2 on each of 2 toughbox minis with a 10.71:1 gear ratio
1 Victor SP controlling each pair of CIMs.
2 other motors each controlled by one Talon SRX via CAN
Weighs roughly 80 pounds
The problem:
Major power drop when turning or driving over defenses
Drop from 12 to approximately 6-8 volts
Potential Causes:
Pneumatic wheels don't have enough air
Braking feature of Victors eating up a ton of power
Victors being power hogs
Victors overheating
Faulty Wiring
Faulty Victors
Extreme friction caused by pneumatic wheels
[Edit] Two motors on one Victor
We know it isn't:
The batteries; did the same thing to 3 of them, at least one is new this year
The CIMs spinning in opposite directions; There is no power drop when the wheels are off the ground.
Any ideas as to what the problem might be? We try removing the braking feature on Monday to see if that is the issue.
Edit: Found out it's actually illegal to run two motors into one controller. Will be fixing the problem shortly
Unread 21-02-2016, 13:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Voltage Drop issues
How much air pressure is in the tires? and could you provide a few pictures of your robot?
and...sounds dumb but I have to ask....the batteries are all properly charged, right? 13.5 volts before you install the battery in the robot?
Unread 21-02-2016, 13:48
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Originally Posted by mypie4050 View Post
<snip>
Potential Causes:
Victors overheating
Faulty Wiring
Faulty Victors
<snip>
The Victors getting hot are much more likely the symptom than the cause.
How much rock do you have on the middle wheels? If you can't clearly see that the front tires are in the air when the robot rocks to the back and vice versa, I am going with extreme friction due to grippy wheels theory.
Also, JVN spreadsheet* says that you're top speed is 17.4fps (14.1fps adjusted). That's a little bit on the high side for a one speed transmission and these grippy wheels (imho). You'd probably have a much better day if you can get more ratio betwixt those CIMs and your 8" pneumatic wheels.
Good luck.
Joe J.
*honestly, checking a box saying that your team promises to use this spreadsheet ought to be required before AndyMark or Vex sells a gearbox and/or a especially grippy tires.
Team #88, TJ2
Unread 21-02-2016, 15:28
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
You're running two CIMs to one Victor?
Don't.
Unread 21-02-2016, 16:13
Victors overheating.
Those two statements may be related.
Unread 21-02-2016, 17:37
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Is that legal? I thought you had to have one motor controller per motor (R52). You can drive the 2 Victors from a single PWM output but not two motors from one Victor.
Unread 21-02-2016, 18:23
AKA: Dr. Joe
FRC #0088 (TJ2)
Wow, I totally missed that they were driving 2 CIMs with 1 Victor. Yes, that is a problem. And No that is not legal.
There are only a handful of motors that let you have 1 Speed Controller and 2 motors, and the CIM is definitely not on that list.
See "Table 4-4: Legal Power Regulating Device Use" in R53.
Only the following motors can have 2 motors on one speed controllers:
  • Automotive Window/Door/Windshield
  • Wiper/Seat/Throttle Motors
  • AndyMark PG
  • Snow-Blower Motor
Dr. Joe J.
Team #88, TJ2
Unread 21-02-2016, 18:45
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
We are having the same problem. We are running one motor controller for each motor controller. We are having a voltage drop when we move and turn. We have gone through the log files and noticed that our current draw is spiking as the voltage drops. We have spikes up to 50a. Our robot is almost undriveable, please help.
2015 MAR District Champions
Unread 21-02-2016, 19:20
AKA: Dr. Joe
FRC #0088 (TJ2)
All closely related threads:
Power draw issues
Battery Voltage problem
Voltage Drop issues
Robot loses communication while going over obstacles
Router browns out with multiple CIMS driving WCD
Team #88, TJ2
