Go to Post 254 bends CIM shafts every now and then in the drivetrain. I didn't believe it was possible until I saw it myself. - AustinSchuh [more]
Unread 21-02-2016, 14:09
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
AndyMark 8 Inch pneumatic hub fail
All,
We took apart our drivetrain to give it some TLC today and discovered all of our 8 inch pneumatic hubs are failing. Very similar to the rhino tread pulleys.
If you are using them, I suggest you take a close look are your hubs.
I just sent pictures to AndyMark and we awaiting for a reply.
Locktite was just applied, it was not there before about an hour ago.
http://imgur.com/a/DX4OH
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 21-02-2016, 14:13
SamM SamM is offline
FRC #5842 (Royal Robotics)
SamM is just really niceSamM is just really niceSamM is just really niceSamM is just really niceSamM is just really nice
Re: AndyMark 8 Inch pneumatic hub fail
Is that loctite on the nuts? Loctite will destroy the polycarbonate hubs.
"The universe is probably littered with the one-planet graves of cultures which made the sensible economic decision that there's no good reason to go into space--each discovered, studied, and remembered by the ones who made the irrational decision." -Randall Munroe, XKCD
Unread 21-02-2016, 14:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
What's the blue stuff all over? Is that loctite? If so, that explains it. Loctite eats polycarbonate, chemically, causing it to become brittle and crack.
Unread 21-02-2016, 14:15
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
They're failing because you put loctite on your screws.
You shouldn't have done that for 2 reasons, the first being that loctite will melt the plastic, the second being that it's pointless because you're using nylock nuts.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-02-2016, 14:27
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Even have been using these hubs successfully without using any loctite.
It seems like this isn't Andymark's fault.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 21-02-2016, 14:38
AKA: Clint Brawley
FRC #0364 (Fusion)
The locktight was just applied to get through the next couple of days!
The damage goes all the way through the hubs.
I highly suggest everyone using these take to a look at your hubs.
Clint Brawley
USAF 1992-2013
Unread 21-02-2016, 14:50
troy_dietz's Avatar
troy_dietz troy_dietz is offline
3D printing and Alliance Captain
FRC #0330 (The Beach Bots)
Team Role: Human Player
Rookie Year: 2015
troy_dietz will become famous soon enough
You don't need loctight when you use nylock nuts...
Looking at how much excess loctite is on the hub, that damage could have easily been done by a combination of chemical breakdown and stress on the plastic.
Unread 21-02-2016, 14:52
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Again, it looks like the failure was caused by the loctite and not the hubs. It causes the polycarbonate to get brittle and crack so I'm not surprised the damage goes through the hub.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 21-02-2016, 14:53
AKA: Clint Brawley
FRC #0364 (Fusion)
Locktite was just applied, it was not there before about an hour ago. After the damage was found a student put the locktite on in an act of desperation.
Clint Brawley
USAF 1992-2013
Unread 21-02-2016, 15:00
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
What did you anticipate loctite helping with that the lock nuts weren't already doing for you?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 21-02-2016, 15:27
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Everyone, please read the thread BEFORE responding.
The Locktite was added AFTER the failure. It is NOT the cause of the failure.
I believe the nylock nuts may have actually contributed to the failures.
Some nylock nuts have larger outside dimentions than the comparable regular nuts.
Forcing the larger nut into the hex opening, and over tightening them may crack the polycarbonate.
Unread 21-02-2016, 17:00
JohnFogarty's Avatar
AKA: @doctorfogarty
What screws/nuts are you using?
I've got 3 robots I'm working with that are using those hubs and none show anything like that kind of wear.
John Fogarty
Unread 21-02-2016, 17:02
Cory's Avatar
AKA: Cory McBride
We did read the thread. He edited his original post to say that it was applied after the damage appeared.
[edit] On closer inspection there are some cracks around the nut cavities that look like they might be consistent with slightly too large of a nut.
2001-2004: Team 100
Unread 21-02-2016, 17:08
AKA: Clint Brawley
FRC #0364 (Fusion)
Look, I'm not trying to get anything other than the word out to check your hubs.
The locktite was applied after the fact.
We are fixing our issue, just make sure you don't have the same one.
Clint Brawley
USAF 1992-2013
Unread 21-02-2016, 17:14
billbo911's Avatar
I'm not saying OP is a liar, but that damage looks a lot like the damage loctite would create when applied to plastic. See this picture
No argument. Locktite WILL cause this type of failure!
Forcing in nuts that are too large for the opening can crack the polycarbonate too. Just my $.02.
