Go to Post Yes, no more dancing. Robots is serious business :rolleyes: - wilsonmw04 [more]
Unread 01-04-2003, 12:40
Kojib Kojib is offline
#0016 (Baxter Bomb Squad)
Kojib is an unknown quantity at this point
Send a message via ICQ to Kojib Send a message via AIM to Kojib Send a message via Yahoo to Kojib
How we do it.
Basically, very strong drive-train and dead reckoning. We are 3-WD, with Bosch drill motors locked into highest setting on front wheels with 4:1. Our Rear wheel is powered with both Chiaphuas. They drop into a helical gear set which sends a shaft through the center of the wheel (on bearings) into a planetary set (the sun, more specifically). We then simply bolt the planets to an aluminum hub we fabricated for the wheel, giving us 15.66:1. The entire rear assembly rotates 180' using a globe motor and a cable (it rests on 102 lycra ball bearings). As the rear assembly rotates, we slow down one of the front wheels to keep it from binding through turns. This gives us approx. 12 fps with enough torque to drag me (160 lbs, 5'8") lying down across carpet (also up the mesh and the HDPE, but I don't like repeating those experiments). All three wheels are 8" Skyway pneumatics inflated to approx. 17 psi.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
