Go to Post Every time i look at my watch and see 3:65 o'clock I always thing, darn i gotta get a new watch... - Kyle [more]
Unread 21-02-2016, 08:25
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Re: Can we fill our wheels with water?
Realize it is not uncommon to fill off road equipment tires with water so this is as far fetched as is sounds. There is no rule specifically against this so it comes down to a judgement call to decide if it is properly contained. IE not likely to spill on the field. Same class as marbles, sand, BBs, and so on. Do keep in mind that this is coming from a team that never puts a robot on the field without a container full of lead & sulfuric acid.
As for as slime goes. We ran it in our Frisbee shooter flywheel to give it mass & balance. Got a controls award for the accuracy of the shooter at one regional. Good thing nobody ask Q&A is it was legal that year.
Unread 21-02-2016, 10:00
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
For the record, I was against this idea from the start. On a related note, 3 years ago we weighed down our robot by filling tube socks with metal bb's and attaching them to the frame. I still can't believe none of them ever tore.
Unread 21-02-2016, 11:36
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Adding water plus an anti-freeze agent to heavy-equipment (and light-equipment too) tires makes perfect sense. I used a small farm tractor with water-ballasted wheels for many years when I was young.
However, zipping around an FRC field is a different matter.
If you want more mass, I recommend attaching solid weights at spots on the robot that move the robot's center of gravity to a better place, in addition to adding mass.
I also recommend testing to find out whether adding mass helps more than it hurts.
Bottom line: Use the right tool for the right job. Your FRC bot isn't a slow moving tractor or earthmover. Water is very unlikely to be the right tool for this job.
Unread 21-02-2016, 11:40
Michael Hill's Avatar
Originally Posted by lethc View Post
If you want to get real heavy I'd recommend pure lead wheels. They're about 12,000 times heavier than air.
Downsides: it's highly toxic and recognized as a carcinogen in CA.
Upsides: Basically everything else
#teamlead
As long as they don't go to a CA regional, it's safe, right?
Unread 21-02-2016, 11:54
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Originally Posted by E Dawg View Post
We were having a debate tonight on whether or not it is legal to fill pneumatic wheels with water. It would be a good way to add some weight to our robot (yes, I know ), but the catch is that it may violate R9. Do you all, especially current/former robot inspectors, believe "water wheels" to be legal?
While tractors do this all the time, please do not put any fluids that could leak onto the field into your tires. There are easier and better ways to add weight to your robot. Plus, you will want that compressibility as you ram into defense and bounce around.
Unread 21-02-2016, 11:57
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
As a Field Supervisor here in New England I would not allow it on the field, whether or not inspection passed it & here is why; All our competitions are done in colleges or high schools on gym/basketball floors. If a tire leaked & caused a wet carpet it could damage the floor below. Not only that, most robots have some type of rubber tire, that when contacting the wet spot probably will slip for the remainder of the match. We don't have the capability to remove the water from the carpet.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 21-02-2016, 12:27
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Originally Posted by sanddrag View Post
What if you pulled the valve stems (the inside part, filled the tubes full of steel ball bearings, and then put the valve step cap back on. Would that work?
5000-ball-bearing-pickup
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 21-02-2016, 21:55
bmire3206's Avatar
bmire3206 bmire3206 is offline
FRC #3206 (Royal T-Wrecks)
bmire3206 is an unknown quantity at this point
does noone remember R9 hydraulics are forbidden.
Unread 21-02-2016, 23:16
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
That happened at Crossroads Regional in 2014, only with lead shot in hidden plastic bags (hence why the RI's missed it). It was a mess both for the head Ref and the field supervisor... Oh the sound of lead shot in a vacuum cleaner...
Unread 21-02-2016, 23:24
PowerfulKitty PowerfulKitty is offline
Drive Coach
AKA: Alex Dalziel
FRC #5576 (Team Terminator)
Team Role: Driver
PowerfulKitty will become famous soon enough
You'd probably be better off filling them with dihydrogen monoxide.
Unread 21-02-2016, 23:47
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Guys, this seems like a serious question, and a lot of these answers really aren't helping.
Look at the blue box under R9. The blue box provides "examples of items that will violate R9". In that list is:
G.Hydraulic fluids or hydraulic items
Typing "hydraulic fluid" in google gives, before any links, a paragraph that starts "Common hydraulic fluids are based on waste, mineral oil or water."
Water is a hydraulic fluid. Hydraulic fluids are specifically listed as something that violates R9. R9 is a robot rule that must be followed to pass inspection and play. Thus water is illegal. QED.
2016: Lake Superior WFFA
Unread 21-02-2016, 23:54
Originally Posted by Tanis View Post
To actually answer your question- In Ultimate Ascent a team in my area came to an event with the wheels on their frisbee shooter filled with water. The inspectors did not allow them to use those wheels due to the risk of the wheels leaking or spectacularly breaking and throwing water everywhere.
While I am not an inspector, I would imagine that this would not be allowed again this year. The defenses cause enough trauma to robots that the risk of the wheels breaking open is too high.
Your best bet would be to ask a Q&A question for an official judgement.
Note that in Ultimate Ascent, there was a similar blue box under R8 (which is the same as R9 this year) which listed hydraulic fluid, and was the basis for the ruling - the description is the justification for calling water a hazardous component, as it doesn't react well with robot control systems. Or, for that matter, the historic 90 year old basketball court we were competing on top of.
Unread 22-02-2016, 08:47
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Sort of a definition thing but I don't see water in the wheels as a hydraulic fluid any more than water in the battery is. I am perfectly fine in being told that water is a hazard to the field & you can't use it rather than stretching a definition.
Unread 22-02-2016, 12:46
nakarsten's Avatar
nakarsten nakarsten is offline
FRC #3669 (RoboKnights)
nakarsten is an unknown quantity at this point
Tire beads would be a good way to weight the wheels.
http://www.amazon.com/E-Z-Tire-Beads.../dp/B00VO4ZODE
