Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 21-02-2016, 23:34
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: HD-3000 camera has wasted many hours
Can you explain the issues you've had?
We've had 0 problems with exposure control on the HD-3000 camera, and are actually quite happy with it so far.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 21-02-2016, 23:46
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
What was your issue? Setting the exposure time is simply USBCamera.setExposureManual(val).
Unread 22-02-2016, 07:32
Dinokaiz2's Avatar
Dinokaiz2 Dinokaiz2 is offline
Use your best judgement.
AKA: Kaiz
FRC #4561 (TerrorBytes)
Dinokaiz2 has a spectacular aura aboutDinokaiz2 has a spectacular aura aboutDinokaiz2 has a spectacular aura about
The Microsoft LifeCam HD-3000 doesn't support having it's exposure set in this manner.
From personal experience and research, I think that the LifeCam doesn't preserve its settings after a power cycle, and, because you can't configure the settings from the RIO, it makes it difficult to have a configured camera on a robot. Usually. Some people, probably including you, wt200999, seem to have LifeCams that just work. They preserve their settings after a power cycle where other LifeCams would not. After hours of digging through Google search results, I haven't found the reason why.
OP -- The way our team solved the problem was by plugging the LifeCam into a Raspberry Pi 2, where we were able to configure its settings live using v4l2. We, however, didn't stream that camera to the dashboard, instead choosing to keep the stream on the Pi for vision processing.
Unread 23-02-2016, 19:32
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Its more erratic than that. I conducted several trials today:
1. Restarted robot code from dashboard - Settings lost
2. Reset settings, power cycled robot, loaded new code - Settings lost
3. Reset settings, plugged back into rio without power cycle - settings lost
4. Did not reset settings, restarted rio from dashboard - settings worked (note, these were settings from before trial 3 that didn't show after trial 3)
5. Restart robot code from dashboard - settings worked
6. Restart RIO from button on rio - settings worked
7. Load new code - settings worked
8. Hard power cycle (turn power switch off/on) - settings worked
If anyone has example code using USBCamera successfully, it would be greatly appreciated.
Unread 23-02-2016, 20:56
wt200999's Avatar
Texas Instruments
AKA: Will Toth
We've eliminated these issues by always writing the camera settings to the camera when the code starts.
We do this with a csv file that has a list of all the attributes that we care about stored on the roboRIO. When the code loads we loop through each setting and set the camera accordingly.
The list of attributes and the list for the csv I have saved in a google doc here. Each tab has some different info, the 'optimal settings' I listed is for the vision tracking and not good for viewing. The 'Values for CSV' tab is a copy of the actual csv file that we send to the robot.
I've attached the LabVIEW code we used, I do not know the equivalent IMAQ function, but it may give you an idea.
Name:	WPILib Camera Set Attributes From File.png
File Type: vi WPILib Camera Set Attributes From File.vi (21.8 KB, 9 views)
Unread 22-02-2016, 10:12
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
rod@3711 is an unknown quantity at this point
We code in C++. For programming, we have 1 1/2 students and one crusty old mentor. Small teams do not have a lot a resources. When we waste a lot of time getting a simple camera to display on the Dashboard, we do not get to spend time on the fun things, like vision tracking or navigation.
Last year we used HD-3000 with CameraServer (like simple vision example) and found we had to go to Dashboard and select Camera HW to get it to work. It was normally washed-out (ie white), but we found if we change frame rate via Dashboard from 30 down to something, then back to 30, it would often work OK.
We use the PC based program to try to set up the HD-3000, but the changes did not persist on the roboRio. It was maddening to see great autoexposure video on PC base programs and crap on roboRio.
This year we switched to USBcamera (due to comments on Chief Delphi) and had more control, but still dissatisfying. The setExposureManual was dark if set to 0, too bright if set to 1, no change up to 10, then white above 10. We had 4 HD-3000, and they each had different settings.
We switched to Logitech and autoexposure works well enough. No settings, just works.
We still have an issue with using SmartDashboard to display video stream. We have to first bring up standard Dashboard, select "camera hw", then start Smart Dashboard and quit the standard Dashboard. This is not the best thing to have to accomplish while setting up for a match. Does anyone have a solution for this it would be appreciated.
I appreciate all support available on Chief Delphi.
Unread 03-03-2016, 11:26
AKA: rod nelson
The latest plugin update 0.1.0.201603020231 solved this. We can start SmartDashboard and the camera feed is live without having to kickstart via "usb camera hw".
I am about to run out of things to whine about!
Thanx.
