Go to Post The only thing more tedious than following a super-long thread is following a super-long thread with the same observations on every page. - CrazyCarl461 [more]
Unread 02-22-2016, 09:55 AM
ShinyShips's Avatar
ShinyShips ShinyShips is offline
Former Operator and Captain
AKA: Andy
FRC #3314 (Mechanical Mustangs)
ShinyShips is on a distinguished road
Gyro Error Message
For some reason our gyro code has stopped working, it worked fined for the last few weeks and now we cannot even initialize a simple Analog Gyro without getting an error message and getting no robot code to the robot.
The error is as follows:
ERROR Unhandled exception: java.lang.RuntimeException: Code: -1005. HAL: A pointer parameter to a method is NULL at [edu.wpi.first.wpilibj.hal.AnalogJNI.setAccumulator Deadband(Native Method), edu.wpi.first.wpilibj.AnalogInput.setAccumulatorDe adband(AnalogInput.java:279), edu.wpi.first.wpilibj.AnalogGyro.setDeadband(Analo gGyro.java:239), edu.wpi.first.wpilibj.AnalogGyro.initGyro(AnalogGy ro.java:56), edu.wpi.first.wpilibj.AnalogGyro.<init>(AnalogGyro .java:106), edu.wpi.first.wpilibj.AnalogGyro.<init>(AnalogGyro .java:90), org.usfirst.frc.team3314.robot.Robot.robotInit(Rob ot.java:82), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]
The only thing we are doing with gyro now is creating it below Iterative Robot, and then initializing it in robotInit.
Any help or insight would be appreciated.
Thanks!
Unread 02-22-2016, 10:08 AM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Gyro Error Message
What port is the gyro on
Could you post this code
Unread 02-22-2016, 10:22 AM
ShinyShips's Avatar
AKA: Andy
The gyro is on Analog port 3
Unread 02-22-2016, 10:34 AM
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Gyros can only be on ports 0 and 1 (those two are the ones the FPGA has accumulators hooked up to)
Unread 02-22-2016, 10:36 AM
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Can you try moving it to port 0 or 1?
I don't think you can connect an AnalogGyro to ports other than 0 or 1 on the roboRIO. See: http://wpilib.screenstepslive.com/s/...ving-direction, it indicates that the FPGA used for integrating the gyro data is only available on ports 0 and 1.
Unread 02-22-2016, 02:31 PM
ShinyShips's Avatar
AKA: Andy
That was it, guess you learn something new even after a 3 years doing this. Thanks for the help everyone!
