Go to Post Anyone know anything about a missing plastic flamingo from NASA HQ? I should mention before you answer that tampering with federal property, even if it's weird stuff from (Dave's) office, is punishable by painful delivery of ChiefDelphi negative rep points. - Rich Kressly [more]
Unread 22-02-2016, 08:28
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
pic: Epsilon Delta v17.0 Control System
Unread 22-02-2016, 08:35
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: pic: Epsilon Delta v17.0 Control System
This is very difficult work to do. Kudos to team 116 for developing some great experience for budding packaging engineers.
While this is all wonderfull and good, I am a bit distracted by your ******* 15 SPEED CONTROLLERS ********
What do you have? Here is a guess:
  • unicorn swerve drive (8 motors)
  • dual motor tuned shooter (2)
  • manipulators in front and back (2)
  • 3-motor scaling arm, 2 for lifting, one for pivot (3)
If you're pivoting that scaling arm, then you are planning on going under the low bar. Then, another question comes up: How on earth are you packaging this wonderful control system in with all of that other stuff controlled by your 15 SPEED CONTROLLERS????
This may be a ingenious contraption for the ages, or a hot mess. I wanna see pictures and video!
Andy B.
Unread 22-02-2016, 09:08
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Only thirteen 20+Amp breakers though. The quantity of cables in their DIO/Analog and MXP ports has me flummoxed. I am quite curious for what 116 has up their sleeve
See you guys in week 1!
GitHub
Unread 22-02-2016, 10:06
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
First I have to say that's a pretty impressive packaging job. I can imagine how much work went into getting everything to fit.
I'm curious how you plan on addressing R40 though. "The PDP and all circuit breakers must be easily visible for inspection"
Do you plan on having to disassemble your robot as part of the inspection process?
The reason I ask, our PD board is "easily" visible if you remove our bumpers and crouch down with a flashlight, I'm dreading the inspection that finds my PD boards visibility not "easy" enough. There are few highly visible places to put it on a robot that's got to fit under the low bar. I imagine this is a challenge most teams building a short bot have had to address.
Since it seems yyou've built this kind of box in the past, what's been your experience with inspection?
http://team2168.org
Unread 22-02-2016, 10:07
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
I only count 14 snap action breakers. I call shenanigans :-)
Unread 22-02-2016, 10:29
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
It's 16, count again.
I have no words. I can't imagine how much planning that took and how much time it took to assemble that.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 22-02-2016, 10:35
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Really cool. I can imagine the hard work it took! Getting it right is definitely worth it though. Keep it up!
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 22-02-2016, 10:49
wilsonmw04's Avatar
Coach
8 x 40 Amp
3 x 30 Amp
2 x 20 Amp +
1 x 5 Amp
__________
14 snap action breakers. I counted 5 times before I posted...
Unread 22-02-2016, 10:59
Chris is me's Avatar
AKA: Pinecone
It's not uncommon for teams to wire more speed controllers than they need, in order for them to quickly switch to a backup in case of a failure. Based on all 15 being wired to the PDB but only 13 having breakers, I'm assuming this is the case here.
I'm guessing they have a 6 motor drive, 2 motor shooter, a motorized drop down intake (at least 2 motors), and 2 to lift with 1 for something else (extra motor for intake, or a pivot for their lift)
Unread 22-02-2016, 11:06
kmodos kmodos is offline
AKA: Alex
FRC #1126 (SparX)
kmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to beholdkmodos is a splendid one to behold
Very nice box. We have something similar, but ours does not fold down. These drop in electrical boxes seem to be getting more popular.
Unread 22-02-2016, 11:12
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
Very nice. We did this on 93 in 2004 and 2005. Is an awesome space saver, though the electrical team didn't like wiring it up...
2012-2016 Wave Robotics Team 2826
Unread 22-02-2016, 11:26
Ari423's Avatar
FRC #5987 (Galaxia)
8 x 40 Amp
3 x 30 Amp
2 x 20 Amp +
1 x 5 Amp
__________
I meant there are 16 spots for breakers (16 Wago ports). They may have added an extra motor controller and not powered it in case something breaks. I know we always do that.
2013: Programmer
Unread 23-02-2016, 09:43
JacobD's Avatar
JacobD JacobD is offline
AKA: Jacob
FRC #1672 (Mahwah Robo T-Birds)
JacobD is an unknown quantity at this point
I am having the exact same problem.
2013-2014: Electrical, Mechanical
2014-2017: Team Captain
Unread 23-02-2016, 10:23
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
FRC #4272 (Maverick Boiler Robotics)
Hgree56 will become famous soon enough
Cool Re: pic: Epsilon Delta v17.0 Control System
Looks a lot like our Electrical Box 1.0 in 2013 and Electrical Box 2.0 in our 2014 robot.
This is our one from 2013: http://www.chiefdelphi.com/forums/sh...d.php?t=113610
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
